SEA_TEC 0 Posted March 25, 2009 Hello, I have scaned in a hand drawn pic in to X4 as a jpg. The other posts I have seen say to convert it to a bitmap. In X4 it does not give me the option to "convert to bitmap" I want to convert this drawing to an .AI I can cut with signcutx2. Can someone give me the exact procedure to do this ? I am completely lost... Thanks in advance, Tim This is the JPG I'm trying to convert Share this post Link to post Share on other sites
Mr Peabody 0 Posted March 25, 2009 I emailed you earlier - I'm using Corel to convert it. I'm teaching myself how to use it so some times things don't always work out. Flames.eps Flames.eps Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 25, 2009 Thats what I need to learn how to do. I see there are extra lines in it though... Share this post Link to post Share on other sites
BigGreen 5 Posted March 25, 2009 heres a vector magiced one needs cleaning FLAMES.eps FLAMES.eps Share this post Link to post Share on other sites
Mr Peabody 0 Posted March 25, 2009 I looked at it again - I didn't see any Sorry Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 25, 2009 The lines showup in Signcutx2, not Corel Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 25, 2009 Ok, I see how to trace an image, but it isn't following the lines that are there... the tips of the flames eather have a single line trailing off from the tip, or the tip has what looks like gouges in it. not very pretty for something that will be cut... Still confused Share this post Link to post Share on other sites
Mr Peabody 0 Posted March 25, 2009 Depending on the quality of original image, it never comes out perfect, you'll need to clean up the extra nodes. You'll get it, remember the undo button if you make a mistake. Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 26, 2009 There has got to be an easyer way to do this.... I found the nodes when I highlite the whole picture.... but when I mouse over a node, click on it and try to move it, the whold picture moves..... Share this post Link to post Share on other sites
Guest stunad, jr. Posted March 26, 2009 There has got to be an easyer way to do this.... I found the nodes when I highlite the whole picture.... but when I mouse over a node, click on it and try to move it, the whold picture moves..... after you trace the picture, you need to delete the bitmap beneath it. select the image and click the shape tool, 2nd one down. It will let you edit the nodes. Hope helps. Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 26, 2009 If you mean the check box "Delete original object, that is checked Share this post Link to post Share on other sites
Guest stunad, jr. Posted March 26, 2009 If you mean the check box "Delete original object, that is checked No, It still leaves the bitmap under the vector. After you trace it, select the image and move it up. You can see it will say "bitmap" on your status bar on the bottom. Click the delete button. If it says "layer 1", that is your vector. Dont delete that one. I am having good results with your image with "detailed logo" trace option. From there you can tweak the trace controls to your liking. Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 26, 2009 i don't see how to "move it up". in the before and after window, it won't move. once I click OK and it goes back to draw, I looked at object manager and it only says layer 1 Share this post Link to post Share on other sites
Mr Peabody 0 Posted March 26, 2009 Select it and then from the drop down menu pick "ungroup all". Share this post Link to post Share on other sites
23putts 0 Posted March 28, 2009 Hand drawn artwork is normally a nightmare to work with....I normally say, give me you your artwork and we will create something similar if not exact. There is an .eps inside the zip folder... Lonewolf Logo.zip Lonewolf Logo.zip Share this post Link to post Share on other sites
SEA_TEC 0 Posted March 28, 2009 Thats sharp looking Putts, Thanks Share this post Link to post Share on other sites
23putts 0 Posted March 28, 2009 NP... There are a couple spots in the flames that could be improved....If you got Corel it can easily be done in Photo Paint. Share this post Link to post Share on other sites
