DUTCH 1 Posted March 25, 2009 I'm a novice at this cutter and posted this message in the welcome area - just copied the text to this location. any help would be appreciated. Hi all. Dutch from Southern Indiana and very new to cutting. I purchased PC630? and could use some help gettting up and running. I restore old antique machinery and will hopefully use the PCUT to make custom relpications of old old stencil work. In some cases I even have to create new fonts. Am I in the right place? I have loaded drivers etc have have USB port COM4 assigned but cannot get the cutter to physically move. It says it is ON LINE and I create a simple text word in SB "SELECT" it, then use the ICON to CUT. It creates a "JOB" and stays on the job list for about 20-30 seconds then goes away. Cutter TEST works fine. I just put the pen in the PCUT and put a regular piece of paper in. Probably something simple but perhaps a bit beyoned me. Share this post Link to post Share on other sites
kenimes 42 Posted March 26, 2009 Do not use the Cut Manager- use the default setting- Direct. Share this post Link to post Share on other sites
