blades 0 Posted March 1, 2009 For those that are not familiar with WYSIWYG, it stands for "What You See Is What You Get". Since my wife will be working primarily with 8.5" x 11" sheets for scrapbooking, I am trying to set up SBE in an appropriate manner. I have set the Work Space Setup to show a 7.5" x 9.5" working area. I would really like to show the full 8.5" x 11" sheet though. The main problem seems to be when you go into the "CUTTER" window. The screenshots below show what I'm talking about. Am I correct in setting the Work Space Setup to show the working window of the cutter, and NOT the actual sheet size? Makes sense to me, as the Work Space Setup seems to be the actual cutting window. This setup leaves about a 1/2" side margin and a 3/4" top & bottom margin when a sheet is loaded into the cutter, as shown on the bottom pic. Help me understand why a layout that fits neatly centered on a 7.5" x 9.5" layout suddenly spills over the edge on the cutter screen. Doesn't the upper left corner in the layout screen coincide with the lower left corner (identified as "1") on the cutter screen? "Fit To Origin" is NOT the answer here, because I want the cut to be as shown on the layout screen, and not pushed into the corner of the cutting window. Thank you for any assistance on this! I'm the one who talked my wife into this unit over a Cricut, so I've got to hand it over to her with some reasonable level of WYSIWYG functionality. Share this post Link to post Share on other sites
sublimation 0 Posted March 1, 2009 Uncheck the "rotate across vinyl" and see if that helps Share this post Link to post Share on other sites
blades 0 Posted March 1, 2009 Nope. Then it's rotated 90 deg. from the layout screen, hence, not as shown on the layout screen. Share this post Link to post Share on other sites
blades 0 Posted March 1, 2009 When I change the workspace setup to "LANDSCAPE" instead of the previously used "PORTRAIT", I get THIS, which is consistent with my previous "cutter" screen results! SB is obviously not keeping the correct scale when it's set up in portrait mode. WTF is that all about?!? Having been a mechanical CAD designer for 10+ years, I have little tolerance for programs that don't behave exactly as expected when it's sent to the plotter. Share this post Link to post Share on other sites
joshlindt 2 Posted March 1, 2009 would you mind posting the file you are using as the test i will see what i can do to help Share this post Link to post Share on other sites
blades 0 Posted March 1, 2009 Thanks Josh, but I already nuked it. I did have better results when using the Landscape layout as opposed to portrait. I've still yet to determine if this landscape "fix" will result in a satisfactory level of WYSIWYG functionality. Share this post Link to post Share on other sites
sublimation 0 Posted March 1, 2009 Try this. click on the "save space" tab and check "save space vertically. Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 That would change the layout though, and that's my whole point: for scrapbooking use, it needs to cut the layout exactly as pictured for making masking pages in a scrapbook. The "Save space vertically" command removes wasted vinyl from between lines of text and maybe other cuts. Share this post Link to post Share on other sites
sublimation 0 Posted March 2, 2009 If you combine all the objects first then do the save space option it wont change the layout. Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 That appears to do the same thing as "Fit To Origin", only it lets you individually select horizontal or vertical, where fit to origin does both. This still changes the layout and does not keep the original borders and spacing from the page edges. I think you're missing the point of what I'm trying to accomplish here. Imagine trying to create an 8 1/2" x 11" masking sheet for a picture frame. You want the cutout(s) centered on the sheet, not pushed down into one corner or to one edge. Therefore, you want it cut as per the layout you created. Same idea with scrapbooking. My wife needs to be able to create an 8 1/2 x 11 page on the layout screen without having to second-guess where it's going to cut at. To explain it another way,The finished product IS the full sheet, not what's cut out of the sheet. Share this post Link to post Share on other sites
cutme 5 Posted March 2, 2009 in the drawing window, create a polyline box around your layout the size of the page and do your layout inside it the way you want it on the page. then yes use the fit to origin. forget about the "workspace window" make it bigger than your project. it has no relevance to the cutter screen. hope this helps. bb Share this post Link to post Share on other sites
Jay2703 704 Posted March 2, 2009 Create you workspace 11" wide by 8.5" tall. (Lanscape) Turn off the fit to origin. Turn off all space saving options. Design how you want it spaced on the paper making sure to leave at least 3/4" on the right side of the design. (So the rollers have something to grab onto) When you load the paper your cutter blade needs to be centered on the right front corner of the paper and make sure to reset your "Home" position. Load the paper with the 8.5 side along the front of the cutter. It should work like that. Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 I think one issue here is that I can't physically locate the center of the cutter on the corner of the page. It won't travel far enough to the right to allow that. As shown in the bottom pic of my first post, that is my home position, with the cutter aprox. 1/2" in from the edge. That's why I created the workspace 7.5" wide, to show the actual cutting width area. I do think I have it figured out now. I just need to have the workspace in landscape mode. Portrait mode simply does not work for this application. Might be fine for normal vinyl cutting though, where you would normally want to use fit to origin to minimize wasted vinyl. Scrapbooking is a different animal than straight-up vinyl cutting, since (in some cases) your finished product is the 8 1/2 x 11 sheet and the shapes & text that are cut out are the waste. That's why it's important to have the visual accuracy in the workspace window. cutme: I think I'm missing your point. If I use fit to origin, it will always position the cut to the corner of the sheet. How can the workspace window have no relevance to the cutter screen? I need the workspace window accurately sized for a frame of reference for the project layout. Feel free to email me an example of what you're talking about and I'll check it out. catia.designer - at - yahoo.com Share this post Link to post Share on other sites
Jay2703 704 Posted March 2, 2009 Blades, are you a Catia jockey? Been using Catia since V2 Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 Used to be... now I'm working for Toyota and haven't done any CAD design in awhile. I mostly used mid-range packages like Autodesk Inventor and SolidWorks, and I only used Catia for about 2 years. Let's see, you're in WA, so I'm assuming you do aerospace work? Boeing? I used to work for Butler International in West Lafayette, IN. We did contract engineering work for Sikorsky. Share this post Link to post Share on other sites
Jay2703 704 Posted March 2, 2009 Used to be Boeing. They sold us off 6 years ago. I maintain all of the CAD stations where I work, do training, manage our PDM system. Still Aerospace. Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 Nice! I'm hoping the auto industry doesn't sink too far, else I will have to chase down a contract job again. My son used to work at Butler also, and did UNIX support there. Share this post Link to post Share on other sites
Jay2703 704 Posted March 2, 2009 I think one issue here is that I can't physically locate the center of the cutter on the corner of the page. It won't travel far enough to the right to allow that. As shown in the bottom pic of my first post, that is my home position, with the cutter aprox. 1/2" in from the edge. That's why I created the workspace 7.5" wide, to show the actual cutting width area. In your picture is the paper loaded in landscape format? I have a PCut so it is a little different animal but it should work the same. You will just have to figure how much no-usable space you there is on your paper and adjust your workspace accordingly. Aerospace is not in much better shape. The only thing that has helped up out is the drop in gas prices. Airlines are not looking to purchase many new planes. There are still CAD jobs out there especially if you are good. Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 The paper is loaded into the cutter in portrait mode (8.5" width into the cutter). And yes, the non-useable space is what prompted me to create the 7.5" wide work area screen. There seems to be a program glitch that doesn't display an accurate view with the workspace area in portrait mode. I'll have to play around with this on AutoCAD a bit. Seems like a lot of times in the past, aerospace was a bit healthier than the auto industry when things were bad. I guess they're both in the proverbial toilet this time though. Share this post Link to post Share on other sites
Jay2703 704 Posted March 2, 2009 If you load it in landscape mode can you move the blade all the way out to the edge of the paper? Share this post Link to post Share on other sites
blades 0 Posted March 2, 2009 No, the max load width is only 8.5" and the home position of the cutter is just inside of the .5" wide pinch roller. I think what you're refering to as landscape mode, I perceived as portrait mode. Anyway, the paper does only go in one way. It's not a large cutter, but it is extremely high quality. Here's the cutter specs: http://www.uscutterdirect.com/USCutter-Raindrop-Craft-and-Scrapbooking-Cutter--RECOMMENDED_p_314.html Share this post Link to post Share on other sites
cutme 5 Posted March 2, 2009 i misunderstood just what you were trying to accomplish. but i got it. work in portrait workspace at 7.5 tall and 9.5 wide. center your design. zero your cutter blade at the imaginary corner of the 7.5x9.5 square on your paper. here is a set of screen shots. bb Share this post Link to post Share on other sites
Jay2703 704 Posted March 2, 2009 If you just center the design in your 7.5 tall area then it seems like you could still give the full 11.0 width so long as you leave enough room for you rollers to hold the material on the right hand side. How Cutme has it set up looks like what I was saying except the 7.5 width. Share this post Link to post Share on other sites
blades 0 Posted March 4, 2009 Thanks guys, that is the ticket. I also downloaded CUTOK Master, which is on the website of the company that actually produces this machine. It's ultra-simplistic, but may actually be just what my wife wants for what she's doing with it. Share this post Link to post Share on other sites
Snoho-Scrap Gal 0 Posted April 19, 2009 Hi Blades, i'm a scrapbooking gal too, i'm trying to figure out the best program to use. Have you figured out if the CutOK software always returns to the same home position after every cut? therefore you can't tell the blade where you want it to start (i think the SBE software does allow this?) I'm trying to wrap my brain around how to make this thing work for me. thanks, Snoho-Scrap Gal Share this post Link to post Share on other sites
