bjbk 0 Posted February 24, 2009 how long should a blade last , or how do i know when it's time to change it out thanks Share this post Link to post Share on other sites
BannerJohn 1,324 Posted February 24, 2009 it depends on what and how much you are cutting. I ususually change blades once a month with regular vinyl,and I cut a lot of vinyl every day. However, some vinyls such as Chrome and reflective seem to wear the blade out faster. You will know when to change...the cuts will start getting a bit lousy,harder to weed. Share this post Link to post Share on other sites
ff-extreme 6 Posted February 24, 2009 How long the blade lasts depends on what you cut with it. Some materials like reflective are harder on the blade. You can tell its time to replace it when it no longer cuts good. Not trying to sound like a wise ass but thats the only way I know when to change. Share this post Link to post Share on other sites
bjbk 0 Posted February 24, 2009 OK cool, i cut regular vinyl and heat transfer material and i haven't had a problem with it , its the original blade still so just looking out thanks Share this post Link to post Share on other sites
jgreen 1 Posted February 25, 2009 Just a tip. The blades from CleanCut seem to last longer than any I've ever tried. Noticably longer! Share this post Link to post Share on other sites
