Ruttenit 0 Posted February 8, 2009 ok I have a logo that has a border and text in the center with black back ground. When I trace it out and move it off the back ground how to I erase the test to put my own text? Share this post Link to post Share on other sites
firemalt 10 Posted February 8, 2009 Sounds like you need to use the node editing tool to delete a portion of the image. To bring it up, push the F2 key, your pointer should change, and then click on the image. To delete a node, put the pointer over the node, click once, and then push the delete button on your keyboard. Hope that helps... good luck. Share this post Link to post Share on other sites
Ruttenit 0 Posted February 8, 2009 Thanks!!! It pretty easy when you know how to do it! Share this post Link to post Share on other sites
