Viper5243 0 Posted February 3, 2009 The title kind of sucks but here is my question. When you go to make a cut the blade and holder are right up against the right side of the machine. Is there a way to start cutting at a particular spot on the vinyl? Like say half way in? Using a refine MH-871 with SBE Share this post Link to post Share on other sites
MikeMan 0 Posted February 3, 2009 From the touch pad, take the cutter offline, then use the arrow keys on the touch pad to move the blade to the location where you want the job to start. Once the blade is in the right spot, press the 'Origin' button. Double check your speed and force settings on the display and you're good to go. Share this post Link to post Share on other sites
Viper5243 0 Posted February 3, 2009 SWEET, thanks a lot Share this post Link to post Share on other sites
vinyliscoolio 1 Posted February 14, 2009 in sign blaster you can go to the jog icon and jog it online then press set origin also. Share this post Link to post Share on other sites
