aries58 0 Posted January 28, 2009 I have cut a in memory of decal and can't weed the darn thing at all.Can't i just cut the whole darn graphic and just weed the cut graphic??i have to feel te cut to see it.it is cut on white vinyl.What am I doing wrong.. Share this post Link to post Share on other sites
acehole 1 Posted January 28, 2009 did you do a test cut to make sure you are cutting all the way through the vinyl Share this post Link to post Share on other sites
Cre8tiveCutter 7 Posted January 28, 2009 on the hard to weed graphics I will weed the outside first and then go from there, the white is the hardest to see! Renee Share this post Link to post Share on other sites
aries58 0 Posted January 28, 2009 did you do a test cut to make sure you are cutting all the way through the vinyl It seems to be cutting through but like a number 9 the top partisn't cut to make the circle in the 9? Share this post Link to post Share on other sites
tory 0 Posted January 28, 2009 Aries maybe when you sent the design to the cutter it is placed too close to the edge so it isn't cutting? I know with my Roland on screen it will look like it should cut fine with what I see but when sent to the cutter occasionally it will be too close to the pinch rollers so the cutter will not cut there. Is that what you are seeing? What is the size of the decal you are trying to cut and what is the width of the vinyl? White is the hardest to weed, especially if small details. I believe it was CutMe who suggested to use chalk, (colored & with a brush or sock) to wipe over cut lines and you will see them better to weed. Perhaps if you post what it is you are trying to weed and having problems we can take a look and tell you where the problem is? Maybe it isn't quite clean enough art to cut yet? Did you first take a look in wireframe to make sure it was ready for cutting? Share this post Link to post Share on other sites
aries58 0 Posted January 28, 2009 It is cuttin the box around the graphic..I am using a premade in memory of in which i chaged the name and date..I am using white orcal651 with 24 cutter.My graphic size is 8.50x11..The circle in my nine isn't cutting at all inside outside is cut..I am using a dentist pick to weed..It would be a lot simplier to cut the entire graphic decal and then just small weeding to be done..lol...Thanks for reply.. Share this post Link to post Share on other sites
tory 0 Posted January 28, 2009 Everything seems to be in order, but where did the "premade" decal come from? Can you see the the center of the 9 in wireframe? Or in your cutter software? There may be something wrong with the file itself. Share this post Link to post Share on other sites
aries58 0 Posted January 28, 2009 Everything seems to be in order, but where did the "premade" decal come from? Can you see the the center of the 9 in wireframe? Or in your cutter software? There may be something wrong with the file itself. Someone made it for me but i replaced the name and date on it.. Share this post Link to post Share on other sites
aries58 0 Posted January 28, 2009 Everything seems to be in order, but where did the "premade" decal come from? Can you see the the center of the 9 in wireframe? Or in your cutter software? There may be something wrong with the file itself. I am thinking i did the numbers and name wrong for cutting? Share this post Link to post Share on other sites
aries58 0 Posted January 28, 2009 Everything seems to be in order, but where did the "premade" decal come from? Can you see the the center of the 9 in wireframe? Or in your cutter software? There may be something wrong with the file itself. I am thinking i did the numbers and name wrong for cutting? I tried to post a graphic i just cut and weeded but can't load it get error.. Share this post Link to post Share on other sites
tory 0 Posted January 28, 2009 Unfortunately, that has been happening lately on the forum. Not sure why. But you were able to get one cut and weeded? Share this post Link to post Share on other sites
Rodger 527 Posted January 28, 2009 I remember reading a post about making it easier to see the cut lines while weeding . It was using a bit of flour on dark vinyl & seems pepper on white vinyl ? I'm sure a member with better memory will help ? Share this post Link to post Share on other sites
aries58 0 Posted January 28, 2009 I remember reading a post about making it easier to see the cut lines while weeding . It was using a bit of flour on dark vinyl & seems pepper on white vinyl ? I'm sure a member with better memory will help ? Share this post Link to post Share on other sites
Rodger 527 Posted January 28, 2009 I read in another thread a minute ago , it was blue chalk line chaulk in a sock for white vinyl , white chaulk for dark ( CutMe was original poster ) Share this post Link to post Share on other sites
aries58 0 Posted January 31, 2009 I read in another thread a minute ago , it was blue chalk line chaulk in a sock for white vinyl , white chaulk for dark ( CutMe was original poster ) Under light i can see the cut,but maybe my cutter isn't cutting the full cut. Share this post Link to post Share on other sites
Jay2703 704 Posted January 31, 2009 I have one of those Halogen lights that shines up and reflects off the ceiling. It makes it really easy to see where you are weeding. Share this post Link to post Share on other sites
dustinjtrr 0 Posted February 2, 2009 can you weed any of the graphic? or are you just having problems with that part? Share this post Link to post Share on other sites
aries58 0 Posted February 2, 2009 can you weed any of the graphic? or are you just having problems with that part? Its hard to determine what needs weeding.I', asuming anything that has a cut mark gets weeded Share this post Link to post Share on other sites
tory 0 Posted February 2, 2009 Aries not everything with a cut mark gets weeded. Maybe it would help you to look at the design cut on the computer screen to determine what needs to be pulled out. Think of the design as having positive and negative areas and all the negative gets weeded because you don't need those parts. Some designs I'll pull the outer background off first to make it easier to see the complete design and where to start weeding. Then I'll choose another easily identifiable spot until I have the whole design weeded. White is def the hardest to see. Share this post Link to post Share on other sites
aries58 0 Posted February 3, 2009 Aries not everything with a cut mark gets weeded. Maybe it would help you to look at the design cut on the computer screen to determine what needs to be pulled out. Think of the design as having positive and negative areas and all the negative gets weeded because you don't need those parts. Some designs I'll pull the outer background off first to make it easier to see the complete design and where to start weeding. Then I'll choose another easily identifiable spot until I have the whole design weeded. White is def the hardest to see. Share this post Link to post Share on other sites
