I know this has been talked about before but am i correct in thinking that the less force used,it is better for your cutter?If mine is cutting fine at 80. Should i leave it alone???I also slowed it down to 12-16 and it seems to cut the smaller stuff smoother...
Do you use more force for thicker stuff like holographic??
Yes, 80 is fine. I usually recommend a pressure setting of 50-100 for vinyl, so you are good there. More pressure may be needed for thicker vinyl, such as reflective or heat press transfer vinyl.
