MitchR 0 Posted January 15, 2009 Ok i just imported my file from inskape to signblazer and the edges of the image still look jagged...i was wondering if this was normal or if i was doing somethin wrong.. i just didnt want to send it to the cutter and it come out all screwed up Share this post Link to post Share on other sites
haumana 1,220 Posted January 16, 2009 Can you post both your original raster image, and the vectorized image? We can check it out for you Share this post Link to post Share on other sites
DanielB 0 Posted January 16, 2009 I work with MitchR. Here are the two files. Thanks Pro-Tech.eps Pro-Tech.eps Share this post Link to post Share on other sites
HySpeed 1 Posted January 16, 2009 The image did look distorted just a little but when I went to edit, the lines look pretty straight. Could use a little straightening but over all, it looks good. Share this post Link to post Share on other sites
MitchR 0 Posted January 16, 2009 Thanks for the input hyspeed Share this post Link to post Share on other sites
DanielB 0 Posted January 16, 2009 Yeah thanks a lot! Share this post Link to post Share on other sites
haumana 1,220 Posted January 16, 2009 I don't know if these will a little smoother, but it might be worth a look. ProTech.eps ProTech.eps Share this post Link to post Share on other sites
MitchR 0 Posted January 16, 2009 Yeah we just dont have our cutter yet so i was wonderin if you thought it might still cut right even though it still looks a little jagged? Share this post Link to post Share on other sites
haumana 1,220 Posted January 16, 2009 hang on for a little bit and I'll let you know. EDIT: Here you go. My scanner sucks, but I can honestly say that the lines are very smooth with no cuts resembling pixelation. Share this post Link to post Share on other sites
MitchR 0 Posted January 16, 2009 Yeah it looks pretty good to me! Thanks for ur help once again haumana Share this post Link to post Share on other sites
