JoeHuang 0 Posted July 10, 2007 I am using a CAD software to design a pattern that consist of squares and circles. It is a DXF file. CorelDraw can open and export the pattern to SignCut-X2. My problem is the cutter (MH365) cuts the squares and the circles many times, for example, the cutter cuts a line of the square many times, then moves to next line and cuts it many times. Does someone know how to solve this problem? Thanks. Share this post Link to post Share on other sites
kenimes 42 Posted July 12, 2007 Make sure you are not selecting more than 1 copy. Also if you are sending to SignCut in .eps format, you might try and export from Corel in .ai format or vice versa. Share this post Link to post Share on other sites
