phred_02 0 Posted June 28, 2007 I'm having a hard time figuring out how to draw lines in Corel Draw that can be cut with signcut. When I draw a line in corel, I can set the outline width the anything I want and it displays on the screen, but when I export to signcut that information doesn't seem stay. How do I draw lines that will have some width when they are exported to signcut? Thanks, Steven Potter Share this post Link to post Share on other sites
dgreenh 9 Posted June 28, 2007 You can use the contour effect in CorelDraw to make a line into something cuttable. Just select the line, apply the contour size of your choice, break the contour group apart and delete the original line. Whether this is a practicle method or not really depends on how the line is being used. Works great on a stand alone line. If you are talking about the outline of a graphic then you probably need to do some welding and trimming then contour the whole thing to get an outline with width. Share this post Link to post Share on other sites
phred_02 0 Posted June 28, 2007 Thanks, that is exactly what I was looking for. Share this post Link to post Share on other sites
Daniel T 0 Posted June 28, 2007 if all you need is a straight line with width.... make a very narrow rectangle and adjust the length to your needs. adjust the width to meet your desired effect. otherwise you're stuck using the contour effect to produce your lines. daniel t Share this post Link to post Share on other sites
