ky1duck
Never
Posts posted by ky1duck
after applying lettering to a semi truck, look great then after 1.5 days there r air bubbles popping up, i put them on wet using water/soap. washed truck first aint sure of vinyl company/type. looked great when first done. now getting airbubbles. what did i do wrong.
thx rob
thanks you just made my wife happy.
rob
i am trying to find a pow-mia graphic and the one they use for the end of the trail of tears. havent had any luck finding a clipart program/ cd that has these 2 on. i have no problem paying for the artwork. i am wanting to cut it to place it on our semi.
thanks.
rob
i have tryed using the trace, but witch one there is quick trace, line art, clipart and a few others all under trace. depending on witch one i use, it eather prints a big box, dose nothing, or draws a bunch of strange shapes. i still think i am doing something wrong.
rob
everthing i read says if doing a wet apply, everything says use application fluid. was wounder it i can use the same thing (1quart water mixed with about 5 drops of dish soap) that i use in window tinting.
thx
rob
i got my new mn721 to direct print/cut in coral x3. now the problem i am haven is how do i convert bmp. files into sonething that i ca plot using pens, i attached the file i am trying to work with have saved it as a cdr, couldnt upload a bmp file. what do i need to do with it or how do i do it. i know the 721 i working because if i drac a bunch of lines on the page and tell it to print i dose just fine. can make it draw it as a vinyl cut out but i only want it to have i line not a cutout. i think that sound right.
thx
rob
i was woundering if any one has been able to get a mh721 to print and/or cut from coral x3 yet, i have been trying al day. tryed using the ce1000 drivers and installed like talked about in this tread, but when is dose try to cut all i get is a bunch of little lines or i get a bunch of long boxes. heck i even tryed using the pnc1000 drivers with no luck.
thx
rob
yes they r was my first time layering too.
thanks guys, i got worked out, put in wrong numbers in the calabration screen.
thx.
just tried using text and had the same problem, did a name that was 3.5 tall and 8.5 wide, but after sending to signcut and telling it to cut, it cut the name at about 9hi x 24wide. all numbers are in inches
thx
i use coral x3 layed out a simple checkerboard pattern, .5 x .5 inch that was 3"wide and 8"long but after sending it to signcut-x2 and telling it to cut the squars cut at about 10" x 10". any idea what i did wrong or is there a problem with signcut using the same size as coral x3. thx for your time.
duck
Vista XP
in Corel Draw
has any one found a 64-bit driver that will work for cutting direct from corel x3. use to us ce1000 win is was running winxp but now i cant find and compatable 64bit drivers for vista. thanks for your time.
duck
