Days Won
498
Everything posted by MZ SKEETER
advice on long straight cuts MH871
MZ SKEETER replied to Desassoc's topic in USCutter Refine Cutting Plotter Discussion
Sorry I cannot help you with the Signblazer signware.,,never used it. maybe some of the fellow Signblazer users can help you out with that.... -
no problem, there might also be something called "optimize cutting order",, -
once again, you will have to tile it... My only signware is Flexistarter8.5 and that is all I need for my business. -
what is your cutting width on your machine? -
is the decal going to be 50"x 70"? -
I do not know anything about Signblazer,,,, but in Flexi,,,,, You can place tile marks, it does NOT cut across your design, it only cuts everything up to the point, then advances, cuts up to that point, then advances until it is at the end of the design,You still have only I big stripe. Not sections. That way you do not have your cutter going from one end of the vinyl ,clear to the other end and back and forth. I make stripes all the time for my business, this is how I do it and they are perfect. In the picture I have put 6 tiles in your design, each at about 14.2" So it will cut all of the first 14".2" then advance to the next 14.2" then advance to the next 14.2" until it gets to the end of the design... It does not cut the lines ACROSS the design,,,, -
are you just cutting the design as 1 long run? or tiling it, so that it will cut (example), all of 12'' before going onto the next part of the design? -
exactly what type of mix are you using for your wet method?
Instructions
MZ SKEETER replied to midsouthprosigns's topic in Business Practices, Sales and Pricing, etc.
not a problem......I send this link to all my customers when they make a purchase. .... -
there is also another store that carries alot of metal vinyls, most sold in 5yds, or 30ft, alot of different colors and alot of different types. Alot with free shipping. store search SPECIALTY VINYL SIGN SUPPLY or ebay member search chrsbrdzy01
do you mean a sign that says interstate 59?
Instructions
you can find just about any type of applying and removing on these videos for applying to just about anything,, http://clipartandfonts.com/TUTORIALS_videos.html -
Cutter head "bumps" the wall . . . ?
MZ SKEETER replied to Z's topic in USCutter Refine Cutting Plotter Support Requests
I don't know anything about SBE, but does it have a place to change the material/vinyl width on the software? So that your actual layout is 10" wide. Not knowing whether your overlapping or not,, but if you change the vinyl width to 10" you would have (3) tiles of 10" x 40" -
Don't do it... LOL at the measurements I told you,,, 1020,, as only a starting point,,,, cut a square or something like L 4" x 1" W then actually measure that area. See if it is real close to being 4" x 1" ... If it is under the 4" x 1" just add a little, like 1022.... If over , take a little away,, 1018... Don't jump to 1200,, It will take you way over.
GRAPHTEC Craft Robo Pro "No Media" Error
MZ SKEETER replied to Inkables's topic in GraphTec Cutting Plotter Support Requests
try hitting the factory reset, worth a shot.. -
How Many People Here Make Signs Full Time? Storefront? Work From Home?
MZ SKEETER replied to bayshorecreations's topic in General discussion
I have been doing graphics 4 years now, and have an EBAY store where I sell them, I have still stayed busy enough to support myself solely from vinyl graphics through the recession, Business has remained strong for me. My main products are vehicle graphics. I only make and sell, not apply. I work fulltime with my EBAY store from my home. -
Graphtec FC-8000 tech
MZ SKEETER replied to Sandstormdesigns's topic in GraphTec Cutting Plotter Support Requests
is that the holder and blade that came with the FC8000? according to Graphtec site standard accessories are (1) Php32-CB09NHS blade holder and (1) CB09UA-1 blade -
the CB15U is only for thick substrates according to my info...different blade and holder for common vinyl -
according to my screen ,, thick substrates need the CB15U-K30 ,, FORCE 20 most of all the rest of vinyls use CB09UA (1) I only use the CB09UA (1) I use flexistarter 8.5 for my sign software,,,AND ALL my other settings are from there.. -
Hello, I have a Graphtec FC7000mk2-75 which I use CB09UA(1) BLUE CAP I also have a Seiki which uses Roland blades,, that Roland blade is too large in diameter, to fit thru the CB09UA holder...the Graphetic spring is keeping the blade from coming all the way thru the holder,,,,, I do not change the length of blade for different mil vinyl. Mostly i use 3 mil outdoor vinyl, and that is what I cut the most, but if I am am going to change to thicker, like chrome. I change the force. Not the blade length. If you go into your cutting controller ...click, list ,edit you will have a screen come up that shows what force goes with each mil (type) of vinyl. or at least close... -
I also just have the design on my screen and take a picture with a digital camera... very ez....
where can i get 3m Vinyl in very specific pantone colors
MZ SKEETER replied to splash0321's topic in Vinyl
this company carrys alot of everything,,, worth a try http://www.gregory1.com -
after you click cut/plot and your production manager comes up, at the top where is says Properties/ click it,then where it shows a picture of a blade, scroll over it, it says CUT, CLICK it, check your resolution numbers, I keep mine at 1020 steps/in click apply click ok...
can you show us a picture of your screen, before you click send?
