Days Won
498
Everything posted by MZ SKEETER
forum member mr300s uses Signblazer with his Graphtec CE5000 use mode HP-GL Use the Signblazer all cutter version.
What is HOME for? I found it in your user manual...... never mind found this in your user manual If the media or home sensors have been disabled (set to DISABLED), be sure to specify the cutting/plotting area (see “4.11 Setting the Cutting/Plotting Area”). If the cutting/plotting area is not specified, the cutting mat may be damaged.
Yes, you can use Signblazer with your Graphtec.. Use Graphtec 50 as the set up cutter. Make sure your cutter is on HP-GL mode. Go into the Signblazer thread and choose the ALL CUTTER version.
Needed 1995 saturn sl2 outline and others
MZ SKEETER replied to horse power graphic's topic in General discussion
have you checked here? The-Blueprints.com -
your welcome.. I love my machine... I have never regretted getting it.. I hope you love yours also.
I have a GraphtecFC7000MK-75 . I thought the measuring just wasted vinyl. I disabled the media sensor, and pinch roller sensor at the git go.. Mine was in background settings. I can place my carriage head right off the edge of the vinyl hit origin and cut. Less waste. No more measuring the vinyl, and just place the pinch rollers over the grit rollers and your fine.
here is one being sold right now on EBAY http://www.ebay.com/itm/Used-Roland-CAMM-1-CX-24-Vinyl-Cutter-accessories-/200701264452?pt=LH_DefaultDomain_0&hash=item2ebaba4244
Well, It's not an insult asking questions first, before you go look at it... user manual dated 2000 for the CX24.
personally, I would be asking EVERYTHING about it before I made an offer.. why haven't you? and if a pick up, I would want to see it cut a detailed design right in front of me..
from another post, flexi 8.1 and 8.6 both work on windows 7. Problems with missing FSUTIL.dll file usually occurs on pirated copies of flexi 8.1 . You can see it in comments on any torrent site with flexi torrent on it . Good luck with it
adjust it in Flexi
try adjusting your blade offset at .05 + or minus and see if that helps
Blade out about the thickness of a credit card? It shouldn't even be out half the thickness of a credit card. Blade out way too much.. Take your blade holder out of the machine and in your hand cut FIRMLY across a scrap piece of vinyl, should only cut the vinyl and no mark on the wax paper backing. Adjust blade to get there, You should just barely see the tip of the blade sticking out of the blade holder. Put back in the machine. Then adjust force of your machine to get the test cuts correct. Still should only cut the vinyl and no marking in wax paper backing. Then also for smaller detailed designs slow the speed of your machine down.
use inkscape.org. FREE http://support.uscutter.com/index.php?/Knowledgebase/Article/View/147/9/how-to-create-vector-images-with-inkscape
Link for step by step Mac and cutter setup. Thanks, BannerJohn!
MZ SKEETER replied to MacCutter's topic in Mac Users Board
that blade holder doesn't look like it's all the way down in the carriage like it's supposed to be. Here is a video from youtube, Of a LiYU,,, that shows it further down http://www.youtube.com/watch?v=A_aRreM4u7E and another Liyu video from youtube.com -
not helped by USCUTTER at all, I volunteer my help, to help others, if I can. -
If on a stand, ground stand to cutter. not all serial cables are equal, a Keyspan adapter, is the best. Is that what you are using? It also depends on the design you are cutting, The refines are limited on memory, I use Flexistarter, and changed my packet size to 1000kb, and curve quality to medium. Which can be changed in DEFAULT JOB PROPERTIES
MH871 cuts weed box through image
MZ SKEETER replied to JDEBO's topic in USCutter Refine Cutting Plotter Discussion
more info from support http://support.uscutter.com/index.php?/Knowledgebase/Article/View/57/1/why-did-my-cutter-just-stop-in-the-middle-of-my-cut -
I removed mine, Banner John already said it. -
I'm not Dan, but Seiki cutters do come with Flexistarter, so I do know it works with that. Flexistarter 10 can be purchased on EBAY, or USCUTTER.com, shop around for best price. Flexi 10 is the latest version.
and if it's wrinkling the paper/vinyl are you sure you have the pinch rollers directly over the grit rollers on the bottom? Not sure how that vinyl cutter is, Some vinyl cutters have a continous 1 piece grit roller on the bottom and the pinch rollers can be positioned anywhere. and some vinyl cutters have seperate grit rollers on the bottom, and the pinch rollers have to be directly over them. -
possibly post some pictures of your problem. I'm not sure what you mean, most vinyl cutters cut from the right to the left. What do you mean load right or left? -
that's a plus, goodluck -
are you sure the vector image is good? -
If using a Mac, are you using the Keypspan adapter? Highly recommended for a MAC...
