Days Won
14
Everything posted by dwp99
Hello and Welcome.
Hello and Welcome.
Hello and Welcome.
- 10 replies
- introduction
- graphic design
(and 4 more)
Tagged with:
Hello and Welcome to the forum.
Glad I could help.
39" x 11" and that includes a little bit of a roll before the hard bend. Take a half inch off of each dimension for the flat area. I can't measure the small panel because of the window trim. So I walked over to the neighbor who has the small panels and his are 15.75 x 11. The Neighbor has no roll just the flat panel out to the hard bend. You might find slight differences from one manufacturer to another
Hello and Welcome.
I've got the long door panel and it's 43.25" x 15.25" from the very outer ridge to outer ridge. I've also got the small panel windows in the door and they measure out to be 20.25" x 15.25" measuring the same way as the large panels. I have a two car door Hope this helps.
excited to be part of community, from Alaska !
dwp99 replied to jusCuttin it''s topic in Introductions
Hello and Welcome. -
Welcome from the west coast of Florida.
Your welcome. I was just sitting here trying to put together a little visual explanation. But if you got it that's great. There are a lot of tool that Flexi offers that I use and they are accessible through the View then click Toolbars. You have space on your desktop to place them. I use Group, Align, Combine, Order and Path Edit. Once you click the check box to choose a toolbar it will place it on the desktop. You can then just grab it with your mouse and drag it to the borders. Here is my desktop
Yes there is. It's in the Combine tool bar and it's called remove overlap. However it can be tricky to use, especially with your EPS file. That file has many layers that need to be sorted out. Once you get the file down to two layers you group each layer together, select both layers and click on the remove overlap icon. Now it's going to trim the bottom layer right back to the upper layer. there won't be a gap between the layers like in Moody Blue's version. For that you'll have put an outline around the rank insignia, remove overlap and then remove the outline. This is a powerful program and if you really want to master it I suggest that you pick up Mark Rugan's tutorial videos. They are well worth looking into.
Hello and Welcome.
Hello Welcome to the forum and good luck with your business.
Hello and Welcome.
Hello and Welcome.
