Days Won
4
Posts posted by louis clarke ii
Damn.. Snowed/iced in around Raleigh.- 1
Nicely done.
- 1
Yep I'm using 220AO. Don't over-preassure the quart tank.
Any questions give me a call (pm me)
Louis
If skarecrow and mark-s can't identify it it doesn't exist.
- 4
Nicely done.
Are they all the same geometric shape? You should add a frew extra pieces for fun, or switch pieces from a different puzzle. One piece would be enough.
I am doing basic etching. I am no artist. when you start worrying about depth of cut I think that is a different level.Remote air eraser by Paasche. this is a great piece of equipment.
Moved on to a bigger Paasche, Once again the up grade was well worth it.
Finally bought a cabinet, only used it a few times but seems to work great, still trying to work out what will be the best gun. I am using the gun that came with the cabinet (cheap cabinet HF) seems to work ok. Working on the vacuum/dust collector system. I have a small dust collector I was not using and in the process of setting that up with my blast cabinet. To many CFM but I found a quick and easy way to lower it. I will try and get some pics in the next few days of the set-up.
You can use the gun that came with the cabinet.
I will try and post some pics up. I use a dust collection system. Still trying to get it put together
Send the file and I can do it real quick. The wording over the ampersand you need to do an outside contour. Then with the slightly larger contour, simplify it will create a void around the ampersand.
Use HTV. Works like a champ.
HTV = Heat transfer vinyl
- 2
Thats tight like new rope.
How wide and thick of material can you cut?
Amen to past and present. I had two freinds killed in a training accident a few weeks ago. Just happens that his ( Andrew Seif ) wife got
The Coca Cola 600 fired up today. MARSOC Marines.
Look up Andrew Seif. See what happend just a few days prior to the accident. A true American hero.
Yep I did use a teflon sheet.
Pretty sweet.
I can't figure out this font
in Fonts
Mark S rocks. This is a nice weeding font.
