Dewi 0 Posted April 11, 2021 Hello, I bought a second hand ce6000-60. I do not have an activation code or CD so I cannot use the Graphtec software. Now i use Adobe Illustrator in combination with Cutting master 4. Now im looking for a program with which I can set the speed, force, etc on the computer. I saw that this program is available from Graphtec, but are there other programs? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 11, 2021 That is the Graphtec Cutting Controller. You control the cutter from your computer. No need to change settings on your cutter. I use it with my Graphtec FC all the time. Download the Controller for the CE6000-60 Share this post Link to post Share on other sites
haumana 1,220 Posted April 11, 2021 If the CM plug in works with your AI, there is no need for any additional software, unless you would really prefer to use a different design software. If that's the case, then any cutting software that will have the right driver for your CE6000-60 will do. Share this post Link to post Share on other sites
Dewi 0 Posted April 17, 2021 On 4/11/2021 at 5:25 PM, MZ SKEETER said: That is the Graphtec Cutting Controller. You control the cutter from your computer. No need to change settings on your cutter. I use it with my Graphtec FC all the time. Download the Controller for the CE6000-60 thanks for your comment! I have searched for the program but can't find it anywhere. Can you tell me where I can download it for free? Share this post Link to post Share on other sites
Dewi 0 Posted April 17, 2021 On 4/11/2021 at 11:15 PM, haumana said: If the CM plug in works with your AI, there is no need for any additional software, unless you would really prefer to use a different design software. If that's the case, then any cutting software that will have the right driver for your CE6000-60 will do. thanks for your comment! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 17, 2021 11 minutes ago, Dewi said: thanks for your comment! It's right under DRIVERS. WIN CONTROLLER https://www.graphtecamerica.com/cp-download-ce6000 Share this post Link to post Share on other sites
Dewi 0 Posted April 17, 2021 42 minutes ago, MZ SKEETER said: It's right under DRIVERS. WIN CONTROLLER https://www.graphtecamerica.com/cp-download-ce6000 Thank you! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 17, 2021 1 hour ago, Dewi said: Thank you! Your welcome. To be able to use the Graphtec Cutting Controller, your vinyl cutter needs to be sitting there ready to cut your design.. or it will not work. Make your changes before you send your design. Share this post Link to post Share on other sites
