GHEENEE1
45 degree blade offset
The 45 degree blade offset I have set for my Titan 2 is .30, is this a correct setting?
there is no set in stone number.  Start at 0.25mm  and do test cuts with the TEST feature and see what looks the best.   You must first make sure you have the blade depth set correctly.  That is posted hundreds of times in this forum.  Do not use the thickness of a credit card.
Each cutter will be different, even the same model. Adjust to what works.  Your welcome :D
  • Like 3
Every machine is different, as well as blade/blade brands. Trial and error. My original LP offset sweet spot is .26 or .27 depending on blade/blade brand.
Like Skeeter said, start with .25, then go from there.
