jbthrock21 7 Posted February 10, 2017 Right now i run a small sign shop as a side job and i gain more and more business. I started with a cheap cutter and signblazer. I used that for the first 3.5 years and finally decide to upgrade my cutter. I bought the uscutter titan 2 28". About the same time i started thinking about upgrading my software and i ended up buying Vinylmaster Ltr. The problem is i find my self doing more and more jobs that involves tiling. Ltr does not including tiling so i have just duplicated the objects cut them in half and then matched them back up. My question is.......i'v never had the tiling feature so is it worth it or is the way i'm doing it now going to be almost the same? Is upgrading to vinylmaster pro worth the $275? i've tried to look at the differences between the two and nothing really sticks out that i need. But i'm fairly new and self trained thru youtube so there might be a whole lot of new tools that i'm missing out on that could make my life alot easier? Any input on this subject would be appreciated! Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted February 11, 2017 Why Upgrade from VinylMaster LTR to PRO? Along with everything in LTR, VinylMaster PRO (Professional) also includes: Ø Tiling/Panelling for Oversize Artwork Ø Cut Documents (Professional & Production Cutting) o Position Artwork, Edit and Layout Easily o Advanced Color Separation o Speed-Weed, Easy Lift and Hanging Marks o More Tiling/Paneling Options for Oversize Artwork o Nesting o Save Cut Files for later and Merge in new Artwork o Greater and Precise control over Vinyl Cutting Ø Advanced Step & Repeat Ø Advanced Tile & Circle Arrays (Arc & Spiral) Ø Text Boxes for Complex Artwork and Menu Boards Ø Advanced Text (Kerning/Tracking/Spacing/Full Justify/Tabs/Bullet Points etc.) Ø Power Shapes (Polygon & Triangle)+ Three more Sets of Basic Shapes Ø Font Manager (View, Install & Use Fonts) Ø Gradient Fills (Linear, Square, Radial, Conical) Ø 3D Modelling (Extrude, Rotate, Spin & Render) Ø Additional Welding and Shaping tools (for Advanced Artwork Design) Ø Curve editing and better Node tools (Knife/Vector Brush and Eraser) Ø Crop, Resample and Flatten Images Ø Extras: Additional clipart, fonts, logos, textures, signs and road signs, as follows: Type LTR PRO DSR Clipart 3,604 9,609 17,279 Future Fonts 5,200 10,500 13,900 Corporate Logos 10,000 40,000 82,000 Signs & Road Signs 313 1,059 1,500 Textures 478 1,164 2,348 Quote Share this post Link to post Share on other sites
