CATWOM1960 2 Posted December 27, 2013 I have winpc pro cutting program it uses a dogal Not sure if I like it have had to replace dogal once thought was expensive What is a better cutting program to use without a dogal Thanks Bonnie Share this post Link to post Share on other sites
mark-s 1,126 Posted December 27, 2013 WinPCsign is a good program, easy to use, dongles are a pain but needed. I design in WinPCsign most of the time export to Illy and cut from it. I did this in WinPcsign Mark-s Share this post Link to post Share on other sites
slice&dice 2,450 Posted December 27, 2013 Mark-s === "Traditional" Bonnie ==== http://support.uscutter.com/index.php?/Knowledgebase/Article/View/190/27/01-signblazer-elements Share this post Link to post Share on other sites
mark-s 1,126 Posted December 27, 2013 Ya I caught it (Traditional) before it went to print. mark-s Share this post Link to post Share on other sites
knucklehead 530 Posted December 28, 2013 The BEST is supposed to be FlexiSign, also the most expensive. Maybe overkill just to cut vinyl. Just design in Corel, Illy, export eps, use sign blazer to run the cutter. No dongles required. SignCut, Vinyl Master, Cutting Master if you have a graphtec. Some are more accurate, than others. Share this post Link to post Share on other sites
