robodude 0 Posted November 16, 2012 I usually copy and paste items from my corel draw x5 to my signblazer with little issue. I have an SC series 24" and windows 7. Now my Signblazer freezes when I hit the cut button. This has been doing this all the sudden since a month ago. It IS NOT item specific. I can reload the program and cut the same file with out it getting stuck. One of the super frustrating things is I can't use task manager to end the program it literally never ends or closes or unfreezes if you leave it open. I been having to restart my computer. Once a day was frustrating now today I can't even cut something. I have had about ten freezes today and cut two things, just blew the afternoon and didn't cut my stuff. I have orders to make and don't know what to do. I have been searching the forum for similar problems and fixes but couldn't find anything. What is going on? Please Help. Additional Questions Can I make the timer clock go away when opening signblazer? Can I change the always check for an update process before opening signblazer? I had a code for Signcut Productivity Pro on my cutter box. I have been meaning to try this as a back up. I just downloaded it and it says my code is invalid. WHAT?? Thanks in advance for any help getting one of these things working. Robert Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 16, 2012 If your on USB connection, put it on a serial cable.or keyspan adapter. Yes, you can use the Signblazer patch to get rid of the timer, do a search for it on the forum Share this post Link to post Share on other sites
Jay2703 704 Posted November 16, 2012 Can I change the always check for an update process before opening signblazer? Robert Yes, change the Target in the Properties of your SignBlazer shortcut to point to SBNT.exe instead of SB.exe: Share this post Link to post Share on other sites
