j4str 9 Posted February 24, 2011 I got cutter set up last night and i got it cutting, but im not sure of two things. Where do i line up my vinyl from left to right, and how much vinyl do i pull out the front? I tried lining my vinyl up with the edge of the machine and it wouldn't work at all it would get all bunched up and make wrinkles and screw everything up. So then i stared lining up the vinyl about an inch over from the edge and it seemed to cut pretty good. As far as out the front, id leave a few inches hanging out and then it would suck it back when it started cutting and my design would get cut off the edge of the vinyl Share this post Link to post Share on other sites
xJoey Dubsx 42 Posted February 24, 2011 Are you setting your starting point on the machine? It doesn't sound like you are. When you get it in the position you want it to start at, hit the last button, the one all the way to the right. Share this post Link to post Share on other sites
