hharley3059 1 Posted April 9, 2010 Still having problems with small cuts ,with the machine lieving little tabs on the weeding how can I fix this so the blade will overlap its starting point on each small cut? I,m useind Flexisign 7.5 Share this post Link to post Share on other sites
TSQUIRTZ 0 Posted April 9, 2010 Got an eps file of the file your trying to cut Email it to me and let me take a look at it. Share this post Link to post Share on other sites
tinaski 11 Posted April 9, 2010 isnt that off set what program are you using to cut with Share this post Link to post Share on other sites
MZ SKEETER 3,934 Posted April 9, 2010 I don't have 7.5 version of Flexi, but see if you have overcut in one of the tabs after you have your design on the layout and on the cut/plot screen, You should adjust your blade offset first though.. in default job properties. Share this post Link to post Share on other sites
tlzimmerman 11 Posted April 9, 2010 Yep...if you are using flexi....you can set it to overcut...that will fix the problem. Also...play with your offset, while I do have mine set to over cut just a tiny bit, you shouldn't need it if you are dialed in correctly with your offset. Share this post Link to post Share on other sites
Dakotagrafx 6,674 Posted April 10, 2010 offset guide Share this post Link to post Share on other sites
pyrophire 0 Posted April 10, 2010 offset guide I get the "too high" when I go from text in illy to signcut, but if i save it as a pdf, do the livetrace and send it to signcut, it does the "good" I still have no clue why it does it, its a pain to fix but its just so weird. It does it inside the design too. Sorry, not trying to hijack the thread, just wondering why the little triangles come out. Share this post Link to post Share on other sites
hharley3059 1 Posted April 11, 2010 I reset my offset and it helped some What i need to know is where is the over cut adjustment ? that I can not find Share this post Link to post Share on other sites
hharley3059 1 Posted April 14, 2010 Id like to get an answer to this is there a "over Cut" adjustment for the MH871 and where is it with flexi 7.5? Share this post Link to post Share on other sites
thredz 1 Posted April 14, 2010 It's called " offset" and you can find the settings in the production manager. Check your advanced settings. Share this post Link to post Share on other sites
pyrophire 0 Posted April 15, 2010 What is weird is that if i do a livetrace of an image then add a drawn shape, the livetrace area will cut out perfect, then the drawn shape will have the triangles on every corner Share this post Link to post Share on other sites
TSQUIRTZ 0 Posted April 20, 2010 Make sure your offset is not set in two places (cutter and flexi) had that problem before with the same problem. Share this post Link to post Share on other sites
Yones12 1 Posted April 29, 2010 offset guide How do you read this? Share this post Link to post Share on other sites
Yones12 1 Posted April 29, 2010 Make sure your offset is not set in two places (cutter and flexi) had that problem before with the same problem. How do you change it in the cutter? Share this post Link to post Share on other sites
MZ SKEETER 3,934 Posted April 29, 2010 offset guide How do you read this? ? , adjust til you get a square test cut. the perfectly square test is GOOD, Share this post Link to post Share on other sites
MZ SKEETER 3,934 Posted April 29, 2010 Make sure your offset is not set in two places (cutter and flexi) had that problem before with the same problem. How do you change it in the cutter? you can read your user manual, if you don't have one, you can download it from the support link at the top of the main forum. http://support.uscutter.com/ Share this post Link to post Share on other sites
Yones12 1 Posted May 2, 2010 Make sure your offset is not set in two places (cutter and flexi) had that problem before with the same problem. How do you change it in the cutter? you can read your user manual, if you don't have one, you can download it from the support link at the top of the main forum. http://support.uscutter.com/ I looked in my manual, and their is nothing about changing offset on the cutter, only in flexi Share this post Link to post Share on other sites
Team Satan 0 Posted May 2, 2010 offset guide Thanks guys, I was searching for this pic 2 days ago Share this post Link to post Share on other sites
