prettybird 0 Posted November 12, 2009 Hi, I am using Flexi Sign pro 8.1 with a Seiki cutter. It was working fine until this morning I tried sending a job to the Seiki and it says it's holding and won't send it. I see under the general tab it's set itself to hold in list and the only other option is save to file. I clicked on production manager and right clicked on my job on the list and clicked send and then it said setup inactive. It was working fine yesterday. Anyone have any ideas? I have a bunch of items I need to get done today. I tried restarting Flexi and restarting my computer and it didn't help. I also have a Roland and I tried sending something to the Roland just to test and it goes through to the Roland. Under the general tab the send now option is there but for the Seiki, the send now option is not there. Please help! Thanks!! Share this post Link to post Share on other sites
nonabelle 5 Posted November 12, 2009 while ur in production manager, look on left side the second box under the material size, there should be another box that usually says send now. has it been change to hold list. if so, change it back. then go to top where it says cut plot and properties, there r two gear icons, click the gears which will open another box, hopefull u will see ur job,hightlight it, then look at the icons above there, u will see a icon with green arrow, select that and it will release ur job to cut.. Share this post Link to post Share on other sites
prettybird 0 Posted November 12, 2009 That's the problem, when I go to that box under where it says material size, the send now option is gone. Only hold in list is there and save to file. No send now option. Share this post Link to post Share on other sites
nonabelle 5 Posted November 12, 2009 wow, don't know then. that hasn't happend to me yet. sorry i couldn't help Share this post Link to post Share on other sites
MZ SKEETER 4,705 Posted November 12, 2009 look in your production manager,, if you already have jobs there,that are not completed, you need to delete them, or it will not allow anymore.. it is probalby trying to still send the past ones you have tried to send, mine has done that before Share this post Link to post Share on other sites
prettybird 0 Posted November 12, 2009 I did delete the previous jobs that didn't work so there is nothing holding there right now. Share this post Link to post Share on other sites
MZ SKEETER 4,705 Posted November 12, 2009 tried rebooting your computer and restart Flexi? Share this post Link to post Share on other sites
Guest fivestar Posted November 12, 2009 In production manager under setup make sure "make active" is checkmarked. Share this post Link to post Share on other sites
prettybird 0 Posted November 12, 2009 In production manager under setup make sure "make active" is checkmarked. That was it. Thank you, so saved my day!! I really appreciate it. Share this post Link to post Share on other sites
Guest fivestar Posted November 12, 2009 BTW, don't you have that SC-500 hooked up? You can cut from it too.......Cuts excellent. Share this post Link to post Share on other sites
prettybird 0 Posted November 12, 2009 Yes I do have the SC-500. I am still getting used to it. I did try cutting from it when I couldn't get the Seiki to work but I think it's cutting too fast so I need to adjust it (don't know how yet) and it was having a motor error. As soon as it finished cutting, it said motor error and made me turn off the machine. It did that two times in a row as soon as it finished cutting. Do you have any idea what causes that? Share this post Link to post Share on other sites
Guest fivestar Posted November 12, 2009 No I don't know what caused that, but to turn the speed down there's a couple of different ways....when you go to cut/plot........go to the options tab and click "edit" middle left side, there you can adjust speed and pressure, or you can turn it off there and use the settings on the printer itself. Share this post Link to post Share on other sites
prettybird 0 Posted November 12, 2009 Thanks, I'll check it out. I really need to get comfortable with using the Roland too. Share this post Link to post Share on other sites
