gogetemgraphix 1 Posted February 16, 2007 what i am wanting to do is put one number inside of another, and alos text to create an outline effect. my problem is when i enlarge them they do not line up right and when i change it in coreldraw by thickening the outline and send it to signcut, it sends the original not the altered one, even when i save it. can anyone help me. Share this post Link to post Share on other sites
Beardown 0 Posted February 17, 2007 Are you trying to do a multi color job? Share this post Link to post Share on other sites
switchatvmc 0 Posted February 18, 2007 I am not too familiar with corel, but i would think it has some of the same features as Freehand mx which has a tool called "inset path", so what i do is make the lettering i want with whatever font i want, then i use the "add points" tool to convert it to paths rather than just text, copy and paste the text so i have an exact copy, then use the "inset path" tool where you can select how much you want decrease the size. If you are doing a multi color job, make sure that your different text layers have are different colors before you send them to the cutter. like i said i am not familiar with corel so this "how to" might not work for you but here are some examples Share this post Link to post Share on other sites
TaterNuts 3 Posted February 18, 2007 Are you trying to do this? I dont use corel, so i really cant help you much. I use WinPCSign... Share this post Link to post Share on other sites
gogetemgraphix 1 Posted February 18, 2007 single color...for example say i have one set of numbers one size and want to make another set larger to put under the other set to create an outline effect with them. i have coreldraw 12 and inkscape. thanks lue anne Share this post Link to post Share on other sites
maverick 0 Posted February 19, 2007 i havent recieved my plotter yet, but i know that w most plotters if your cutting directly from corel you have to have the line weight set to .oo1mm . setting a thicker outline wont work. you need to use the contour tool and set it the distance desired from the text, then seperate it frome the original. Share this post Link to post Share on other sites
gogetemgraphix 1 Posted February 28, 2007 Thanks Maverick, i meant to tell you before now....it worked. lue anne Share this post Link to post Share on other sites
