Just a quick question. when cutting 6 lines of 2 inch letters at 40 inches long the plotter starts the cutting works great then hangs and makes all kinds of racket. I changed the color of every 2 rows and cut this out same length and all and works fine. I was trying to do a complete back window with everything lined up and failed. I have cut out a huge graphics on the side of a race car and no problems. Any clue? yes still under warranty.
I got the job done just dont understand why it does this with letters and not graphics (or I have not run into it yet).
This has been an awesome fun event full plotter and hope nothing is wrong....
Jay
First thing if you are using USB...try to change to serial...USB can be flaky.
2nd....ground the cutter, static can make things like that happen.
If it only does it with letters (fonts) why dont you convert you text to Lines (IE graphic) before you cut?
