Days Won
6
Everything posted by kainth.c.s
At the end of the day, we have to work as per the client's directions as we are getting paid by them. But, a general trend is: Simple and clear are surely making a comeback against Fancy and Cursive when information needs to be displayed. Calligraphy, Cursive and Fancy fonts are preferred for parties hangups and easel boards. At least this is what I have figured out from the works I have done in the past
It's just a trade name call it maxmetal, Probond, Dibond, Signbond, Alcopanel and many more. But stuff wise it is the same Aluminium Composite Panel......HDPE sandwiched in between Powder coated Aluminium sheets (02 mm to 0.5 mm Thick). Excellent option for display exterior signs as well as interior ones
It may not if you are using the same software to create the file as well as cut it. But if using different software, different version of the same software or importing the format from the internet, then these stroke3 widths may cause an issue. After all, we never come to know what preferences the supplier has set on his/her software for the files
Give a check when you type something in one software whether it comes with a stroke added by itself or not. Nearly all the times when the files are transferred from one software to the other, the default stroke from one software is picked up by the other as an extra width. The same thing happens when the same image is traced in different softwares. I use illustrator and it has the default stroke set to 0.25 mm or 0.01 inches. So whenever I type something or trace an image, it adds it up by the default and it comes to play when I transfer the file in flexi Sign for cutting.
Things like these are quite common when two programs with different unit preferences are used, or same program is used while installed on other than usual operating platforms. Designs downloaded from the internet especially eps and ai files when opened into programs scale differently as they are saved with units "px" Sometimes these text have the strokes added to it in order to make them extra bold. They change the sizes when these strokes play up That is one of the main reasons I always prefer to work with silhouettes instead of text versions while cutting. It is an extra bit of work but worth it in the end You best bet would be to keep a couple of sizes handy from the customer and as you import the text or silhuoettes, scale them to the sizes
Sorry for the late reply. If still searching, try Anydore font
Roland old Model cutter: Help required
kainth.c.s replied to kainth.c.s's topic in Roland Cutting Plotter Support Requests
I can grab a usb to serial port adapter or the cable suitable for that computer. Yes I do have Flexi 10 starter version I do not have signblazer but I do have Signcut. Will it support Windows 7? I mean will there be any aftermarket type of driver available by any chance that can support the cutter with windows 7 if I can;t find anything on Roland's site? -
Hi Everyone All good. So I have refixed it with the following: I tried the following on two shirts each 1. On 2 shirts, Temperature about 325 deg F with the pressure on the higher side with pressing time about 25-30 seconds 2. On 2 shirts, exactly the same but with the shirts wet 3. On 2 shirts, another press by turning the shirts inside out At the moment, the sticker looks like it has clended on to the shirt which is what I was after. I tried to remove on small black letter and it almost pulled the fabric. Fingers crossed, I have handed over the shirts to the owner. Let's see what he comes up with Many thanks for your help folks
TROUBLE STRUCK: HELP NEEDED Hi Everyone I am facing the issue of black vinyl peeling off in the adjoining picture. It has been happening only with the black vinyl, rest of the colors are fine. This has been happening after a few days of the first wear. I have applied Heat transfer vinyl (other colors of vinyl on to the colored fabric) sometimes using household iron and sometimes using heat press but have never experienced this before. Here are the details: HTV Brand: BFlex Preheat temperature: 150 deg celcius Pressing time: 15-20 seconds Shirt material: Pure Cotton (Brand Anko available at Kmart) Heat press used: Vevor I tried pressing the vinyl again using heat press but on one or two shirts it started to peel off again after I test washed it. I am giving it a normal wash with maximum temperature of 80 degree celcius (in accordance with the data sheet of the vinyl). I had a word with someone else in the company and was told that the white fabrics and garments are coated with some sort of stain resistant coating so they don't get stained while passing through many hands. This may interfere with the sticking of the vinyl. What am I doing wrong guys?
I was also thinking on the same line that there might be a coating on the shirts available at retail stores. I ordered them online but I am sure they were picked up from a couple of retail stores at different locations and dispatched. I am preheating the shirts before pressing them on with the graphics but the letters have been falling off. The coating might be just to enhance heir look or may be a stain resistant one particularly done on white fabrics so as to avoid them getting stained because of being touched by so many hands. What do you thin?
Over here in Australia, it is Tradie :)
I need to delete small cuts in my png file
kainth.c.s replied to a topic in VinylMaster CUT, LTR, PRO & DSR
Trace it into a silhouette. Many of the small cuts will go away. Try Photopea for tracing. it is a free online tool and gives good results -
Hello everyone I have been asked to make this bonnet sticker combining a couple of colours on to the matt white base. Shall I tape this whole decal up and put it like a normal decal or I put it without the tape as the base white is a single piece? Also, I have used the vinyl which the supplier claims to last 5 to 7 years (Ecotac and Suptac from Hexis). What shall I say about the oife ofthe decal on the bonnet of the car? Any ideas to prolong its life?
Thanks mate
Also, the car is a black Chevrolet Cruze and the sticker came as a Birthday surprise for the owner
Dakota don't worry. Here we value your opinion worth of a couple of grands. Yes Suptac is a calendered vinyl which is less prone to stretching and I found it a bit better than cast when layering it in positions.
From the album: works to show
Thank you My concern was dure to the fact that being on a hood it would bear heat both from outside due to the weather and from inside due to the engine underneath. I explained the situation and he is happy even if it stays for about 3 years which I am pretty confident it will
Thanks everyone for the inputs. I decided to give the tape a go, with the same doubt in mind that it may scratch or may start to come off with the movement of the edges of the squeegee. I used the wet application method but was able to peel the tape off while the vinyl was still wet. It did lift up but I managed to squeegee it down. Here is the end result. Many thanks for the inputs
