101LEDs
Members-
Days Won
2
Everything posted by 101LEDs
Anyone interested in one for their cutter can pm me anytime.
If they don't cut the same vinyl (651/751/etc) at the same speed and pressure the results won't be comparable. Same goes for degree of blade and blade brand. A test like this should only have one variable, the actual machine. I don't think there will be that much difference at the same magnification.
Welcome aboard, nice looking RC.
Do you mean tiles so you can cut a large design in several pieces and install them so they look like one piece? http://forum.uscutter.com/index.php?/topic/46666-how-do-you-do-vinyl-wider-than-your-cutter/
I used 2 passes with higher pressure and it was deep enough to break apart cleanly.
New cutter on the way and looking for Software
101LEDs replied to lablover's topic in General discussion
I got VMP 4 and like it alot. It supports ARMS and manual contour cutting, not sure what other goodies a CE6000 has that aren't speed/reliability related. You will end up wanting a printer to go along with VM once you play with everything. I looked for and tried all the demo's possible and Flexi was one that I couldn't find either. Using a trial of AI and Photoshop CC to see how they work right now too. -
http://forum.uscutter.com/index.php?/topic/33114-vinyl-express-gcr-61-help/ But, if what I read (elsewhere) is correct.. The cutter is circa 1998. No clue if you can find a driver. I read maybe Roland pnc1100 will work but that was on windows.
How are you connecting the Mac to the cutter? Is it grounded to the stand? Lot of static electricity in the air?
Looks great, bet nobody else on your street had them They are calling for snow here, kept most people in since it was cold and raining.
What needs to change to make this better? JPSS Shirt
101LEDs replied to 101LEDs's topic in Show your work
I thought there should be another way, post it when you get a chance. Thanks -
I figured it out, you have to print from PS or similar. -
I have the all of the 7010 profiles from Cobra on the pc, how do I check which is being used? -
Inkjet printer Model LC-750 Standard Print Speeds at 600*600dpi Output in square feet per hour (Square meters per hour) 600*600dpi with 60 Pass Resolution Speed(smph) 3pass 600*600dpi 10.2 4pass 600*600dpi 9.6 6pass 600*600dpi 7.2 8pass 600*600dpi 5.9 Ink Type 4 Colors Dye Ink Application LECAI series and Novajet series large format printer Specification CMYK Print Technology Thermal Inkjet, IMT Technology Max Printing Size 152cm,60" Ink Delivery System Continuous ink system with 500ml refillable reservoirs Media Compatibility coating paper,PP,Sticker,Photo paper etc. Media Handling External automated media take-up&feeder system Print Resolution 600*600dpi 300*300dpi File Resolution Accepts 600*600dpi or 300*300dpi files Interfaces IEEE1284 Bi-tronics ECP PARALLEL Buffer Standard 32MB, Extended 64MB Power Supply 215-245V,50Hz Power Consumption 20W idle,100W typical,150W maximum Noise Standby:≤60dBA, Working: ≤72dBA Work Environment 15-30(59-86) 20%-80%RH,non-condensing Windows Drivers Windows 98/ME/NT/2000/XP Certification CE Language English,Chinese CW 105kg Package Size 277cm×77cm×64cm
Need business cards to match Oracal 751-063
101LEDs replied to express2100's topic in General discussion
PMS 802 / 802x ? Seems close. -
I would take a piece of the vinyl or color guide to show them to. Doesn't sound like Kustom printz is very "custom". -
I don't know if this helps. C - 30.7, M - 50.3,Y - 0.0,K - 25.4 R -112.0, G - 190.3, B - 62.0 That is from VMP4's color library. It has about 35 different vinyl mfg. built in with the different colors and styles for each. 751-063.svg -
Maybe give these people a call. http://www.printingforless.com/2-Color-Printing.html They might be able to help. -
Have it printed on heat transfer paper, that might work better and quicker.
No, it was sent in an email and it was deleted after I read it. Probably buried somewhere on the site but no clue as to how to find it.
UPDATE. Due to a lot of sellers not going along with the new Holiday return policy they have totally dropped it. There will be no loss of Top Rated status or forcing you to offer returns up to 6x the length of time required to be Top Rated. What they are offering is a 5% incentive if you decide to offer the longer Holiday returns. So you get 25% off the selling fees instead of 20%. My math says it isn't worth it. EX. $300-20% = $60 discount $300-25% = $75 discount + 3 months of extra trouble/extra time = No thanks.
Please help identifying correct creation model number for JSI-24
101LEDs replied to Ionic's topic in Creation PCUT Cutting Plotter Support Requests
It is a Copam which is a ?? http://www.jsisign.com/techsupport/index.html -
From the album: Vinyl Cutter task lighting
LP2 cutter with our custom task lighting.© Not for public or commercial use without permission.
