Days Won
18
Everything posted by mfatty500
Graphtec changing speed?
mfatty500 replied to mfatty500's topic in GraphTec Cutting Plotter Support Requests
well, it is cutting with controller, i guess i can tough it out. Thanks for all your help, you to dakota -
speed and force are ok, but the condition changes to 9 with the controller should the status light keep blinking? -
usually 10-15 yes hitting enter, this is the first time this unit has given any trouble in 5-6 years -
i'll try it Thanks -
blade issues, that's when noticed my setting were not right i probably changed them but did not notice til today -
then that is a no, all controlled from the cutter I just used it this morning and it was not cutting well, then I noticed that the settings were all screwed up so that is when I reset. -
as far as I know, can you clarify? nothing has changed except for me changing defaults, I have changed them before with no issues. I don't think it can be anything serious as it does not change in the GP command. -
8.6, windows 7, I reset it to factory defaults because all my conditions were all screwed up. I don't remember changing any settings so I reset it. -
sorry, yes as soon as I send the job to the cutter, it only does it while I'm using flexi, normal when changing command to GP for Corel thanks. -
Machine for resharpening vinyl cutter blade
mfatty500 replied to NAFLAH's topic in General discussion
I do not like clean cut blades as they don't last any longer than the cheap blades as I cut 99.99% glitter heat press vinyl, my supplier does not carry them anymore, that is why I am asking for them. thanks. Thanks for the references. Money is no object. -
Where are you getting the china made blades from? -
sorry i do not know anything about that software, it should be in your cutting software, hopefully somebody will chime in here or do a search of this forum.
Sounds like you have to much blade extended, try backing the blade back a little and reduce the force and do 2 passes. Also are the circles symmetrical? Sorry i do not anything about that cutter. Hope this helps. Mike
How do you turn a solid object into an outlined object ?
mfatty500 replied to grafx worxs's topic in General discussion
and he has not been back since. markk that is -
Go to the Funeral home that handled the funeral for you and ask to get into a grief counseling program that they offer. Most of them have them these days.
I am having problems also, using r-tape AT60 with Matte White FDC 4200 series it will not pick it up, but I had some of the same tape that was 2 years old and it picked it up. I am wondering if it is the FDC? The tape will pick up avery, oracal, etc. Any suggestions are welcomed. Thanks Mike
If you can't find the font just retrace the numbers? The font in the photo is good 'ol brush script.
Anything to do with Baton Twirling. Thanks Mike
already have a few of them, thanks
what is it? put it up here maybe someone has it. quit beating around the bush!
atta boy!
Then don't show your work. No see, no copy.
Aachen, is close.
You learned how to use Photoshop?
