Days Won
3
Everything posted by signyouup
Here's a link to Signblazer downloads. Signblazer
The Sign Blazer Elements v7.0.0. was uploaded about 3 hours after the above post.
I have the original Sign Blazer for USCutter hosted HERE. I'll add the SignBlazer Elements v7.0.0. (hybrid/cracked) there tonight sometime.
Pinch Rollers on MH 721 not moving easily
signyouup replied to Ginchgonch72's topic in MH Series Vinyl Cutters
Did you raise the rollers first? -
Cutting thin features too fast can also cause that. If you still have issues after adjusting the blade, lower the pressure and speed.
How do i cut the outline of a page?
signyouup replied to zoannkeck's topic in VinylMaster CUT, LTR, PRO & DSR
Some software has what's called a "weed box"that makes a box a set distance larger than whats being cut. -
MH721 MK2 - Part of image cutting correctly
signyouup replied to Slipit1's topic in MH Series Vinyl Cutters
Try slowing down and backing off the pressure. -
They really really suck!!! I'm just jealous.
cutter sometimes cuts a dashed cut line
signyouup replied to phil lancaster's topic in Creation PCUT Cutting Plotter Support Requests
Does it tend to do it in a certain direction? -
Are you setting the origin for each job?
Pcut ct630 stopped responding all of a sudden
signyouup replied to dplovin's topic in Creation PCUT Cutting Plotter Support Requests
Check Baud Rate settings on cutter and make sure everything matches on the computer. -
Sample display boards?
signyouup replied to Scratchthejeepguy's topic in Business Practices, Sales and Pricing, etc.
White about a whiteboard? Nice smooth surface and and has a frame. -
Newb questions about my new SC2
signyouup replied to Scratchthejeepguy's topic in SC Series Vinyl Cutter Discussions
Cut a little off the pen. -
12x12 or 15x12 sheets? 15" TITAN3
signyouup replied to StayHungryFL's topic in Table TITAN Series Vinyl Cutter Discussions
The weld thing is usually done in the design software. Depending on the program, you may have to convert the text to curves before welding. -
Have you run a test cut from the control panel. That will let you know if it's hardware or software.
issue with my mouse, Scroll wheel wont scroll on websites
signyouup replied to eprcvinyls's topic in Off Topic Section
I had problems scrolling once and opened up the mouse and found a fuzzball stuck on the sensor. -
Anyone here use a Hix Hobby Lite Swing Away Heat Press Machine - 9" x 12"
signyouup replied to eprcvinyls's topic in Heat Presses
You could add triangles centered at the top and bottom of the design and cut them out when you're ready to press. -
In Corel it needs to be a vector to export as one.
My plotter HM cut random lines like stairs
signyouup replied to DAVID INZUNZA's topic in USCutter Refine Cutting Plotter Support Requests
Strange the line is a repeating pattern. -
Blade Pressure Will Not Change. Please Help!!
signyouup replied to Downlow350's topic in General Help
You are changing it on the machine? -
New high tech thievery. Watch this! https://youtu.be/bR8RrmEizVg
Print on regular paper and use a pen in the cutter to confirm things.
Convert the PDF to EPS. https://docupub.com/pdfconvert/ I think the text will come out as vector.
