Days Won
498
Everything posted by MZ SKEETER
hope your not planning on selling them....copyright infringement. But Goodluck on your search.
you can try and vector it in Signblazer. That is free also. download on first page http://forum.uscutter.com/index.php/topic,21665.0.html
www.inkscape.org Vectorising in Inkscape SolutionThis walk through explains the basics of vectorising in Inkscape. Step 1) Import your image. Click File>Import, find your file and click OK. Step 2) Select the image, go to the top of the screen, click Path>Trace Bitmap. Step 3) The Trace Bitmap menu will then open. Here you can select how you want your image vectorised and adjust the settings. You can also generate a preview. Once you are happy with the preview click OK and close the Trace Bitmap screen. Step 4) Now you will have your new vector image and the old raster (bitmap, jpeg, gif etc) image stacked on top of each other. Seperate the two and delete the raster. Step 5) Play around with your new vector image!
all the manuals are in the support section. just download them. they are in downloads and knowlegebase http://support.uscutter.com/
you need something like corel, illustrator, inkscape is FREE vector software. www.inkscape.org.
What cutting software are you using with that cutter? The ad I found says Artcut. Most people have problems with it. don't know where you bought your cutter, but they are sold here and the drivers are here http://www.macroenter.com/Articles.asp?ID=147 If that don't work. try a Roland PNC1000 driver, it is a generic driver
PCUT ctn630- connecting issues
MZ SKEETER replied to malachiind's topic in Creation PCUT Cutting Plotter Support Requests
I don't have either. but found this post, maybe it will help you http://forum.uscutter.com/index.php/topic,7909.0.html -
USCutter MH-series Vinyl Cutter 25" worth it?
MZ SKEETER replied to xJoey Dubsx's topic in USCutter Refine Cutting Plotter Discussion
Signblazer is design and cut program. Sign cut is cut only. You can download Signblazer right now from this forum, at the top of the Signlazer thread and mess around with it. Download on first page http://forum.uscutter.com/index.php/topic,21665.0.html -
First of many questions!! Help!
MZ SKEETER replied to Debra Payne's topic in LaserPoint Cutting Plotter Discussion
your cutter cuts from right to left, so you have to start at the far right on your vinyl. , and place your vinyl to the far right. to stay away from the reset button, and hit the origin button to start from that area. Also in Signblazer there is a place to CHECK MARK, rotate across vinyl, to change directions of your width of design. . -
have them cut some detailed work on it, while you are there. also like Dakota said. great deal.
Windows 7 problems
MZ SKEETER replied to lawabidn's topic in USCutter Refine Cutting Plotter Support Requests
http://support.uscutter.com/index.php?_m=downloads&_a=view you might be able to try the generic driver Roland PNC 1000 also -
Windows VISTA USB setup for Refine plotters
MZ SKEETER replied to MarcelC's topic in USCutter Refine Cutting Plotter Support Requests
have you checked the drivers here? http://support.uscutter.com/index.php?_m=downloads&_a=view you might be able to try the generic driver Roland PNC 1000 also -
your Signcut code should at the bottom of your confirmation for your order. Check there.
you can read it yourself. Yes for Mac also http://www.sc-x2.com/ If you haven't gotten your code yet for Signcut, you can still download it for a week and try it out.
grounding cable?
MZ SKEETER replied to SouthShoreDecal's topic in USCutter Refine Cutting Plotter Discussion
put it up in BUY SELL TRADE section. not here... -
Looking for best cutting software - Sign Cut expires next wek
MZ SKEETER replied to mcrimm's topic in General discussion
what operating system are you using? Windows? Mac, I have used Flexistarter for over 4 years, very user friendly. It is a cutting software, and can import alot more different formats than most cutting software. Or if you are using windows, Signblazer is a free cutting software that can be downloaded right from the forum. Free. Most others are design and cutting and cost quite a bit. You can get Flexistarter8.6 for windows and 8.5 for Mac. and you own it. version 8.6 also comes in a contour cutting version for $130. regular $99 http://cgi.ebay.com/FlexiStarter-Vinyl-Cutter-Flexi-Sign-Starter-MAC-/300462187986?pt=LH_DefaultDomain_0&hash=item45f4f125d2 http://cgi.ebay.com/FlexiStarter-Contour-Cutting-Vinyl-Cutter-flexi-starter-/280555712949?pt=LH_DefaultDomain_0&hash=item41526c71b5 http://cgi.ebay.com/FlexiStarter-8-6-vinyl-cutter-FlexiSign-Flexi-Sign-NEW-/280558166114?pt=LH_DefaultDomain_0&hash=item415291e062 -
to connect to older computers that have serial connections. PC towers
there is an adapter for that also. Just in case http://cgi.ebay.com/New-9-Pin-DB9-F-25-Pin-DB25-M-Serial-Port-Adapter-/250614456175?pt=LH_DefaultDomain_0&hash=item3a59c91f6f
You plug the keyspan USB to your computer, then connect the end of Keyspan to the serial cable you got with the cutter, then the end of serial cable to your cutter. I have been using Flexistarter for over 4 years. very user friendly., I use with windows though. can I come visit you this winter? LOL I live in Indiana, cold...
New computer, zen green not working
MZ SKEETER replied to Connor's topic in ZenCut Cutting Plotter Discussion
I don't have windows 7 just referring to other posts on the forum, who have mentioned it , but here is a page from Microsoft http://www.microsoft.com/windows/virtual-pc/download.aspx -
have you tried> until you can get US CUtter support... to run it in XP SP2 compatibility mode? -
WOW!! thanks Rodger. you made my day!!!
new guy with pcut..signblazer help
MZ SKEETER replied to banzaimini1's topic in Creation PCUT Cutting Plotter Discussion
First off . are you importing your files? NOT OPEN...Signblazer doesn't have anything to do with your cutter being a paperweight. If you don't like Signblazer, which is FREE software, then purchase design/cutting software you do like that you feel comfortable with. You also got Signcut with your cutter, which you can use inkscape software (FREE) with, or can import other vector images with, TRY IT. YES, put up a screen shot. -
pcut blades
MZ SKEETER replied to megamark's topic in Creation PCUT Cutting Plotter Support Requests
I don't have any, am already stocked up on Graphtec blades. I have never heard of any one renewing them. This may not fix your problem at all, It can also depend on the cutter and the vinyl you are using. and your adjustments, Blade should barely be seen. You can actually take your holder out of the carriage and cut the vinyl, if it is going into the backing at all, the blade is out too far and picking the vinyl up. It also depends on the design your cutting, on how small of detail, I have not seen a Pcut cut real small details. But a Graphtec will. -
pcut blades
mention the forum for a discount http://www.cleancutblade.com/ct_catalog.htm
