richie6 0 Posted November 5, 2008 I want to purchase a vinyl cutter to make small logo's and possible signs for family member's businesses. I don't have a lot of room where my computer is and also don't want to spend too much. So I am looking at the the "MH Vinyl Cutter 12" or 25". I don't really need a 25", but i noticed all the rolls of vinyl are 24" wide. Is there a plus to get the 25"?? Also, can you use the 25" without a stand?? Share this post Link to post Share on other sites
kenimes 42 Posted November 5, 2008 Yes, most vinyl rolls are 15" or 24" widths, but when using a table top unit without a stand with media rollers, you have no place to put the roll anyhow, so the majority just cuts a sheet off of the roll for the particular job you are going to cut. The advantage of the 25" is the stand with media rollers, and the extra width for larger projects. If what you will be doing will never require more than 12" in width, just go with the MH365 12". The amount of space you have also plays a factor in your decision. Share this post Link to post Share on other sites
richie6 0 Posted November 5, 2008 Is it difficult to cut down the 24" rolls to fit? Canyou use the 25" cutter without a stand? Share this post Link to post Share on other sites
kenimes 42 Posted November 5, 2008 It is not difficult to cut a sheet of vinyl off of the roll, no. Yes, you can use the 25" without the stand if you want to. Share this post Link to post Share on other sites
richie6 0 Posted November 19, 2008 It is not difficult to cut a sheet of vinyl off of the roll, no. Yes, you can use the 25" without the stand if you want to. What do you use to cut a roll down to fit?? Share this post Link to post Share on other sites
kenimes 42 Posted November 19, 2008 You cut a sheet off of the roll with some scissors. You need a specific machine to cut a roll down I believe. Share this post Link to post Share on other sites
