TLE 0 Posted October 20, 2008 Do you know how to set up registration marks in signblazer, I can't find any section in the program to do it. Share this post Link to post Share on other sites
cutme 5 Posted October 20, 2008 make your own. they are just a couple of squares. what i do is make one then duplicate it. position them where i want them and presto, reg marks. bb Share this post Link to post Share on other sites
TLE 0 Posted October 20, 2008 Tried that the only problem I had was when you are in the cut screen and you pick the color you want to cut it will pick one color only and or all the colors, how do you pick the color and also the reg marks and not the other color, hope thet makes sence. Share this post Link to post Share on other sites
KageDesign 3 Posted October 20, 2008 Make your first set of squares the same color as one on your vector color , then make another set of squares the next color, and so on if you have alot of colors, just make sure that the sqaures over lay each other in the same spot, if you need to change colors on your vector, select a section and pick a color from the color pallet on the bottom of the program, and then make one set of squares that same color. Share this post Link to post Share on other sites
cutme 5 Posted October 20, 2008 you can select the colors you want in the cut screen by holding down the ctrl key and clicking on the extra color. bb Share this post Link to post Share on other sites
TLE 0 Posted October 21, 2008 I will give that a try thanks Share this post Link to post Share on other sites
TLE 0 Posted October 22, 2008 It did work, I made the reg marks a diferent color and then selected them for each color I was cutting. Thanks Share this post Link to post Share on other sites
