Countryside Graphics 0 Posted October 14, 2008 Is there anyway you can contour cut from the pcut 630 brand? Share this post Link to post Share on other sites
Guest sciondrgn Posted October 14, 2008 Not with the standard pcut, you would need the lazerpoint to contour cut Share this post Link to post Share on other sites
duke 12 Posted October 14, 2008 checkout mortalimmortal posts august 10/08 he has info on this. i was to try his info out but my puter took a hissy fit and i forgot all about it untill now hope this helps duke Share this post Link to post Share on other sites
MGOMEZ 0 Posted November 7, 2008 you can contour cut with the p-cut using signgo pro,and there is a new version of flexistarter 8.5 with contour cutting available on ebay.i got signgo pro for $199.00,it will contour cut with p-cut,the flexi 8.5 just came out a couple of weeks ago,sells for $129.00,looks like a pretty good deal.i am not sure of the name of the dealer right now,but i think it was flexistore. the seller is desaypc.as far as i know both of the programs will contour cut with almost any cutter brand,i know for a fact that signgo pro cuts with the p-cut.still tring to dial it in.lots of other nice fetures in signgo pro.well worth the money,not as many with the flexi. Share this post Link to post Share on other sites
duke 12 Posted November 7, 2008 you can contour cut with the p-cut using signgo pro,and there is a new version of flexistarter 8.5 with contour cutting available on ebay.i got signgo pro for $199.00,it will contour cut with p-cut,the flexi 8.5 just came out a couple of weeks ago,sells for $129.00,looks like a pretty good deal.i am not sure of the name of the dealer right now,but i think it was flexistore. the seller is desaypc.as far as i know both of the programs will contour cut with almost any cutter brand,i know for a fact that signgo pro cuts with the p-cut.still tring to dial it in.lots of other nice fetures in signgo pro.well worth the money,not as many with the flexi. have you got signgo pro contour cutting yet? i have not been able to with trial version. regards duke Share this post Link to post Share on other sites
Primal Rage Outdoors 0 Posted November 7, 2008 Flexi 8.1 also has the contour features, but at this point looks like a complete pain in the but to line everything up Share this post Link to post Share on other sites
MGOMEZ 0 Posted November 12, 2008 I HAVE DESIGNED AND CONTOUR CUT SEVERAL DESIGNS WITH SIGNGO PRO. IT WORKS LIKE IT SHOULD,LINING UP THE CUTTER HEAD WITH THE REGISTRATION MARKS IS THE HARDEST PART.THE NEXT TIME I TRY IT I WILL PUT THE PEN INTO THE BLADE HOLE ON CUTTER HEAD WHEN CALIBRATING THE CUTTER SO I CAN MANUALY PUSH PEN DOWN TO CHECK ALIGNMENT.FOR THE PRICE SIGNGO PRO IS THE BEST,IN MY OPINION.THE ILLISTRATION TOOLS ARE REALY NICE.I WOULD RECOMMEND IT. Share this post Link to post Share on other sites
