TruckDriver 0 Posted October 8, 2008 What would happen, say if (and only IF), somebody set the blade offset to 25mm instead of .25mm? Share this post Link to post Share on other sites
TruckDriver 0 Posted October 8, 2008 I did, and I hope that's what is causing my problems. It's cutting like 1/2 of a pentagon all over! Share this post Link to post Share on other sites
JoeCamaro 11 Posted October 8, 2008 Yup, that happens when offset is not set up right. It happened to me once. Share this post Link to post Share on other sites
TruckDriver 0 Posted October 8, 2008 Sweet, thanks. I just figured that out last night, but the other guys were sleeping and I didn't want to wake them up with the cutter. I'm in Iraq, and we're packed into the rooms pretty tight. The day is almost over, so I will check it soon! Thanks for your help! Share this post Link to post Share on other sites
JoeCamaro 11 Posted October 8, 2008 No problem I hope everything work after you change the offset value. (It should) Share this post Link to post Share on other sites
TruckDriver 0 Posted October 8, 2008 It's working GREAT! Thanks for your help! Jay Share this post Link to post Share on other sites
JoeCamaro 11 Posted October 8, 2008 No problem outbreak. I actually didnt do a thing, it was you. You found out the problem youself and got it fixed yourself, I just told you the same thing happened to me once when I changed the offset value. So thank you Im glad you go it working perfectly. Joe Share this post Link to post Share on other sites
