garageink 0 Posted August 13, 2008 I have been using my copam cutter for cutting heat transfer vinyl but am now looking to get into sign making and decals. I have the Copam CP-2500 and I am using Oracal 651 and 751 vinyl. My cutter is doing nothing but tearing it to pieces. Are there specific settings I should be using. Please help cause my local midget football team will be upset if I cant make there window decals. I am not extremely experienced because I mainly concentrate on screen printing. Any and all help is appreciated!! Share this post Link to post Share on other sites
Guest fivestar Posted August 13, 2008 Change the blade depth and/or pressure. Heatpress vinyl takes more pressure then sign vinyl does. Share this post Link to post Share on other sites
gg 1 Posted September 5, 2008 I have a Copam 2500 I cut heat press vinyl and Oracal 651, 751 & 851 all on the same settings.. 10cm/130g/0.25mm blade depth not sure.. when I put a new blade in, it's trial and error to get proper depth.. I've had mine 18 mo.. only used 3 blades, I cut about 2hrs per day.. hope this helps.. Share this post Link to post Share on other sites
