jjdude 0 Posted August 6, 2008 Newbe question here; I have been putting muticolor decals on in steps. Like put the put the back color down and then the layer over the top. Is this correct? Is there a way to assemble a decal for quick application at the job site? Thanks all, Dude Share this post Link to post Share on other sites
Jay2703 704 Posted August 6, 2008 I have done some where I use the opposite method. I start with application tape big enough for the entire design. Then I start with the top layer and use the same application tape all the way down to the bottom layer. Share this post Link to post Share on other sites
jfought 120 Posted August 6, 2008 I have done some where I use the opposite method. I start with application tape big enough for the entire design. Then I start with the top layer and use the same application tape all the way down to the bottom layer. this is the way we do it. unless it is a large graphic then we will layer it on the sub straight. Share this post Link to post Share on other sites
jjdude 0 Posted August 8, 2008 Thanks for the ideas, one more question though; When you are layering this on the transfer tape how do you keep bubbles out? Is is ok to use app. fluid at this point when assembling? I know that if you get the backing that the vinyl comes on wet, it sux! Thanks again. Dude Share this post Link to post Share on other sites
Jay2703 704 Posted August 8, 2008 I just do it dry. How big is the design? Share this post Link to post Share on other sites
