Guest crshirts
Sandblasting cabinet
Guest crshirts
Weekend project I did. 2 sheets of particle board and a few 2x4s.
I use pressure pot (low pressure unit) that requires only 10 to 20lbs of air pressure
and 180 grit aluminium oxide. So wood cabinet isn't a problem and cost less than $100 to make
I will post plans if anyone is interested. I used saw and straight edge most of cuts.
Carl
Nice work. I did some glasses a few years back with a sand blasting cabinet, Made some good $$ on them But I had to hand cut the designs. I have thought about getting a cabinet of my own to play with again.
Here are a couple of economical units
http://www.homier.com/detail.asp?SessionKey=IN93Elf%2ftyY3MarPT0dyfBSOMES29P%2fdZpY31DgwGAhBvBwJ4Dm%2fq%2b1MZPYQnFyadeJSRQ%2bFyx2B&dpt=9&cat=129&sku=03091
is 79.99 and
http://www.homier.com/detail.asp?SessionKey=IN93Elf%2ftyY3MarPT0dyfBSOMES29P%2fdZpY31DgwGAhBvBwJ4Dm%2fq%2b1MZPYQnFyadeJSRQ%2bFyx2B&dpt=9&cat=129&sku=02763
For 149.99
I have the larger unit and it works great but it does come unassembled - when assembling I used sportsmans goop silicone on all joints as these always leak sand!!
