glixgraphics 0 Posted June 21, 2008 had this cutter for awhile, and i am really starting to notice that its not cutting circles correctly. Also noticed that the dots on the letter "i" are weird looking, it happens with all fonts.I did test #2 on the machine and it cut perfect circles, so is there something in blazer that could be off?. also I ahh ... inadvetently did change the y scale in the cutter recently, was well hard to explain, i wrote down the number it was on and well i lost it...could this be the cause??...either way does anyone have the default x and y scale #'s that the machine is set at from the company?? I have my blade set correctly, and i even messed with the offset seems to make no difference (but in the process have found a sweet spot). Thanks Share this post Link to post Share on other sites
routesmith 0 Posted June 21, 2008 Wow, weird, I havent seen that before, what program are you running? Share this post Link to post Share on other sites
firemalt 10 Posted June 21, 2008 Wow, weird, I havent seen that before, what program are you running? He mentioned "blazer", so I guess SB or SBE? Is there a reset/setting default option? Share this post Link to post Share on other sites
routesmith 0 Posted June 22, 2008 Duh, yeah,hahahaha I must have missed that...Yeah I would try resetting the defaults if you can... somehow reload the driver if you can,... Wayne Share this post Link to post Share on other sites
firemalt 10 Posted June 22, 2008 Worst case... delete and reinstall the program. Share this post Link to post Share on other sites
JoeCamaro 11 Posted June 22, 2008 Check blade offset and play with it. Change blde. Share this post Link to post Share on other sites
nonabelle 5 Posted June 22, 2008 Check blade offset and play with it. Change blde. so joe, was that the recent problem u were having and did fix it when u changed ur blade? Share this post Link to post Share on other sites
JoeCamaro 11 Posted June 22, 2008 Havent tried it yet. Im to lazyto plug the cutter Share this post Link to post Share on other sites
nonabelle 5 Posted June 22, 2008 Havent tried it yet. Im to lazyto plug the cutter i sho hate it. LOL Share this post Link to post Share on other sites
