decal_villain 0 Posted September 24 Vinylmaster pro 28sc also have a 34 surface go type c to usb cable Machine works fine when I send cuts But can't adjust the pressure or speed The only button that work is reset But if you push reset and other buttons the cutter notice like pause and enter Share this post Link to post Share on other sites
decal_villain 0 Posted September 24 Vinylmaster pro 28sc also have a 34 surface go type c to usb cable Machine works fine when I send cuts But can't adjust the pressure or speed The only button that work is reset But if you push reset and other buttons the cutter notice like pause and enter I will try soon to swap the button control from my other cutter to test if I need to order other controller Share this post Link to post Share on other sites
