repodon 1 Posted June 14, 2008 how do i take a picture of what i down loaded and send it to the cutter also if i see a picture of some thing how can i copy it and then send it to the cutter example say i seen some thing on the forum that i like to cut out with my cutter how would i do this thanks in advance if it isnt a jpeg or eps file ect ect thanks in advance donald roddy north carolina 336-293-4123 Share this post Link to post Share on other sites
polarkiss 1 Posted June 14, 2008 Well you will click on the file if it is an EPS and download it to your computer. From there you can access it through your cutting program. Usually import and re-size/color to your specifications. If it is a jpg you will need to download it to your computer and vectorize using either Inkscape, Illustrator or there are many other programs that can help you out from there. Share this post Link to post Share on other sites
repodon 1 Posted June 14, 2008 ok thanks a bunch yea it is down loaded to my documents now all i have to do is do the rest of what you said to do thanks a bunch thank you so very much Share this post Link to post Share on other sites
repodon 1 Posted June 14, 2008 inkscape now your way ahead of me ive seen it but dont know nothing about it Share this post Link to post Share on other sites
swaneejuggalo 0 Posted June 15, 2008 nkscape is super easy to use Share this post Link to post Share on other sites
haumana 1,221 Posted June 15, 2008 nkscape is super easy to use Ditto. Not to mention, since Vector Magic went commercial, it's the best free vector software out there. It looks a lot more daunting than it really is. Just remember that the cutter requires a vector image to cut. ".eps" files work well, and that not all ".eps" files are vector. It took me a long time to figure some of these basic 'rules' out. Share this post Link to post Share on other sites
duke 12 Posted June 16, 2008 how do i know if a file is jpeg, eps, or whatever? duke Share this post Link to post Share on other sites
haumana 1,221 Posted June 17, 2008 usually if you right click on the file and select properties, it will tell you what kind of graphic file it is. just be aware that even if it is an .eps (Encapsulated Post Script) file, it doesn't necessarily mean that it is a vector version of the graphic (which is what the cutter requires). Share this post Link to post Share on other sites
