unikcreativeco 0 Posted June 10, 2023 Anyone have any idea if I did something wrong or did they just package the wrong size? Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 11, 2023 Maybe try installing the brackets onto the outside of the frame (legs)? Share this post Link to post Share on other sites
arty-rc 719 Posted June 11, 2023 Also, there might be a "right" and "left" bracket. Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 11, 2023 arty-rc, I was thinking of that at first, too. However, the remaining distance of those rollers doesn't seem to be covered by just reversing the brackets (whereby the overhang with the wheel bearings slots faces out instead of in). It's hard to tell from the photo, but switching them over L-to-R just may be enough additional gap to handle the rollers. Share this post Link to post Share on other sites
unikcreativeco 0 Posted June 12, 2023 Yeah so the only solution I can think of is mounting the brackets to the outside which means I'll have to switch the legs inside out as well... Kinda of a pain... This isn't just a coincidence either because the first cutter I received was so beyond damaged and the replacement had the same size rollers as the first box... Makes no sense to me. Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 13, 2023 You might want to affix those brackets onto the legs using self-tapping screws, if taking apart the whole stand is too much hassle. Share this post Link to post Share on other sites
