slice&dice 2,469 Posted March 23, 2023 APPLICATION INSTRUCTIONS FOR DECAL 1. Clean window or desired smooth surface to remove dirt, grime... (70% ISOPROPYL ALCOHOL) Do not use Windex or other similar ammonia-based product, as it leaves a trace behind that is not suitable for decal applications 2. Remove and discard decal backing material (white paper) ---- peel away carefully, making sure the decal stays on the clear "transfer tape" HINT: Don't take the tape away from the backing, but rather, take the paper away from the tape. 3. With the backing paper completely removed from the decal & transfer tape, gently place the decal with the sticky transfer tape onto the surface of the glass (or other desired smooth substrate) in the position you want the decal to be and rub it down lightly with your hand --- be careful, once it's down, it's down ! 4. Take a credit card and use the edge as a squeegee to firmly wipe over the surface of the transfer tape to affix the decal onto the glass or substrate. The decal adhesive is activated by strong pressure. 5. Finally, peel off the transfer tape gently, at a 45-degree angle. The decal will adhere to the surface, but make sure that the decal remains stuck onto the glass and doesn't come back up ---- sometimes you have to 'coax' it from letting go of the transfer tape. 6. Your decal installation is complete. If there are bubbles present under the decal that cannot be removed by working them to the edge, a small needle or pin can be used to puncture the bubble and remove the trapped air 2 Share this post Link to post Share on other sites
CWS 3 Posted April 5, 2023 Thanks for that. It is complete and will be very useful to give with decals made for friends, etc. Share this post Link to post Share on other sites
