kneal4747 0 Posted May 31, 2008 Why sometimes, I download a eps graphic someone has posted, and its not there when I go to look at it ?? Its just a black box, that I open, and it almost looks as if its loading , and then nothing is there ?? And at other times it is What am I doing wrong ?? Share this post Link to post Share on other sites
go hodags 0 Posted June 1, 2008 i have that problem too and wondered why Share this post Link to post Share on other sites
MattS 0 Posted June 2, 2008 They all end with .EPS but they are all not the same. Every program saves an them different and even some program will give you an option of saving it different. Take Illustrator for instance. If you have a newer version of AI and just save a EPS in that version, more than likely you will have to vector it again in SB. But, it you take that same file in the same AI and save it as an EPS but in version 8, it will work just fine in SB. There even seems to be a difference in files between a EPS from photoshop and one from AI. Eventually you will get to the point where you will automatically resave all the files you download in a program you know that works. It will save you some time and headache. Share this post Link to post Share on other sites
