mmracing601 0 Posted May 30, 2008 i can get this to load in sign blazer, when i try to cut it, it shows black and white. i converted it from .jpg to .eps on vector majic. how can i get it to one color? or the right question is, what did i do wrong? brian Share this post Link to post Share on other sites
Jay2703 704 Posted May 30, 2008 You have a couple of options. Vectormagic usually creates a white rectangle background. Delete it. Then you can either cut both colors at the same time (in the cutter menu hold down the CTRL key while selecting the second color) or select everything (CTRL + A) and Arrange + Combine to make everything one. Share this post Link to post Share on other sites
mustangconv85 0 Posted May 30, 2008 try these they may need cleaned up a little i replaced the text in the second one cat-chicken.eps cat-chicken2.eps cat-chicken.eps cat-chicken2.eps Share this post Link to post Share on other sites
