Mikuda 0 Posted September 19, 2019 Hi there! I have very uncommon problem with my setup - not sure if it's plotter or software oriented. THE SETUP: Plotter is Graphtec FC7000-100 with latest firmware 2.10 GL - updated just recently, but problem occurred with previous version too. Set as GP-GL. Connected via USB. Windows 7, Cutting Master 2 and - if it even matters - Corel Draw X7. THE PROBLEM: After loading and measuring vinyl sheet plotter shows it's correct dimensions (mm). But Cutting Master program, reads these dimensions 10x bigger! Any clues? Please look at images: Cut Area on plotter is 532x248 MM But Cutting Master shows 532x248 CM Any clues? Please help! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 19, 2019 removed by me. Share this post Link to post Share on other sites
Mikuda 0 Posted September 19, 2019 Thank You for input but I don't see how is Your answer related to my issue? Units (cm, inch) are irrelevant here - tested it. Firmware version is irrelevant too - I did it only as attempt to eliminate this problem but it didn't change anything. There are three options in Media Size section: - "default preset" which is also too big and is independent from plotter and pretty much useless - "user defined" where I can input correct settings manually but it's cumbersome. - small button with "?" which should read dimensions from plotter. And It kind of DOES - numbers are correct but units are messed up. (don't assume what functions are "default" if You don't know the program). - FINALLY - as I mentioned - I'm working in Corel Draw. I don't need another sign making software. So Anyone else? Cutting Master users maybe? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 19, 2019 Good luck Share this post Link to post Share on other sites
