hump1977 0 Posted April 30, 2008 Is there any way to change the file type to be able to cut it? I have an item that is a gif file and I want to cut it but signblazer won't allow me to... new at this and need some help Share this post Link to post Share on other sites
TeresaMc 0 Posted April 30, 2008 I too am a newbie so I am sure there are much more qualified answers, but you need to convert it to a vector file. I don't have the skills to do that myself very well yet (hopefully I'll learn) but you can do it with Inkscape(free download) or VectorMagic.com (pay site) Share this post Link to post Share on other sites
Guest Terry Posted April 30, 2008 You can only cut vector files, take your gif and vector it in Inkscape. http://www.inkscape.org/ download in upper right for PC's. Share this post Link to post Share on other sites
routesmith 0 Posted April 30, 2008 Are you trying to cut the image out once printed or are you trying to cut detailed line and curves in it? Maybe you can upload the image and we will tell you what the best course of action is to help?? As Terry and Teresa said, you have to convert it to a vector, To do this, open up inkscape with your image and go up to the PATH menu item and click on trace bitmap. Wayne Share this post Link to post Share on other sites
firemalt 10 Posted April 30, 2008 Post up the image, and I'm sure someone would be more than help to convert it for you if it's a decent sized image. Share this post Link to post Share on other sites
haumana 1,221 Posted April 30, 2008 Post up the image, and I'm sure someone would be more than help to convert it for you if it's a decent sized image. Yup-yup! Just make sure you post it in the right bulleting board .... now that we have a "Mature Audience" board too. regular (clean) graphics mature (dirty) graphics Share this post Link to post Share on other sites
firemalt 10 Posted May 1, 2008 We'd hate to see you get banned from the forum for an innocent mistake. Share this post Link to post Share on other sites
hump1977 0 Posted May 1, 2008 Here is the file I am trying to cut out. Share this post Link to post Share on other sites
haumana 1,221 Posted May 1, 2008 That's a small file with a low resolution. I enlarged it, but it will probably still need a little more touch-up. sitting lab.eps sitting lab.eps Share this post Link to post Share on other sites
juniorranger 0 Posted May 1, 2008 Try and scan it in and "select item" and then go to "image" and select "monochrome" and then click "vectorize", When you go to "cut" or "cutter" to cut the image it will give you a message that it wont cut it, just click ok thru the message and it will usually cut it anyway.. Has always worked for me anyway, maybe i have just been lucky, but try that and see what happens, hope i could help.. Share this post Link to post Share on other sites
firemalt 10 Posted May 2, 2008 Haumana, what did you used to convert that? I did this one in Inkscape, and it came out fairly good... maybe just need a minute to clean up a few spots. sitting lab II.eps sitting lab II.eps Share this post Link to post Share on other sites
haumana 1,221 Posted May 2, 2008 Inkscape ... I don't know how to use anything else ... except for VM, and I've tried my best not to turn into an addicted VM-junkie. Share this post Link to post Share on other sites
firemalt 10 Posted May 2, 2008 I used Inkscape as well, and our images came out completely different. Share this post Link to post Share on other sites
haumana 1,221 Posted May 2, 2008 I think it's because I imported into PS first, then cranked up the resolution ... apparently not enough though. I think next time it'll go straight to Inkscape and be done with it. Thanks for point that out though! Share this post Link to post Share on other sites
