TPAKTOPA 1 Posted December 8, 2014 Hi, I recently bought Graphtec CE600-60 and i'm trying to get used to the software (Cutting Master 3) I've noticed that when I export a few vector objects from CorelDraw x7 to CM3, only the objects which are not grouped appears in Cutting Master 3. I've checked the CM3 options, but I can't find anything. Is anyone faced this sort of issue and can this be fixed via Cutting master 3? Any advice will be helpful. Regards Share this post Link to post Share on other sites
TPAKTOPA 1 Posted December 9, 2014 Just figure it out. See below how this can be fixed. From CM3 Left Hand side Menu "Selection Only" needs to be unticked. (see the screenshot below) 16-dec-2014 UPDATE: I've just realized that this does not solve the issue that I've got. It just imports all object from the entire document. But if you want to import only certain objects which are grouped it does't import anything. I may try to write to Graphtec support team, about that. It is simple enough to ungroup the objects, but on my opinion it was not supposed to be this way. Share this post Link to post Share on other sites
