Countryside Graphics 0 Posted April 1, 2008 Does anyone know how to do a layered job or outline? Share this post Link to post Share on other sites
dgreenh 9 Posted April 7, 2008 Explain a bit more about what you are asking... or upload an example file. Share this post Link to post Share on other sites
Countryside Graphics 0 Posted April 7, 2008 I am wanting to make a shadow outline like 2 numbers on top of each other. Share this post Link to post Share on other sites
Guest Terry Posted April 7, 2008 I think it's the outline tool on left tool bar in Corel, then export to eps. But I'm not sure, I don't use it much but I tried it and it worked in Flexi. Share this post Link to post Share on other sites
dgreenh 9 Posted April 14, 2008 Select your text or object Effects > Contour from the top menu bar A window will open on the side and you can select how much offset you want. You also need to select the direction that you want the contour to go. Inside or outside or center. I usually use outside. After you get it looking the way you want: Select the the contoured group then Actions > Break Contour Group Apart from the top menu You will now have 2 separate objects that you can color and trim or whatever you want to do with them. Share this post Link to post Share on other sites
