Guest Terry Posted February 27, 2008 Any of you ever try this thing before? it's only like $20.00 nice for LONG straight stripes on boats, vans, campers etc.... http://www.monokote.com/accys/topr2420.html Share this post Link to post Share on other sites
laserman70 2 Posted February 27, 2008 Have not use it, it looks like a great tool to have for the money. Thanks for the link Share this post Link to post Share on other sites
Jerry Bonham 1 Posted February 27, 2008 Interesting. Should be a great tool. Don't see how they could patent it? I collect old vinyl cutters and things associated with them. I have a vinyl slicer/sprocketing machine. This slits vinyl to 382mm (15") and punches holes along each side. This is for the old Gerber vinyl cutters that used to sell for about US$30K each new. It uses the exact same principle for slicing to the correct size. So does every other machine i have seen for slicing vinyl. Interesting? Jerry from SignBlazer. Share this post Link to post Share on other sites
dbtoutfit 5 Posted February 27, 2008 We use these on the RC planes etc. They work great. It's extremely important to get the monokote, ultracote, econocote or vinyl dead straight on the roller to get a perfect straight strip. These use typical razor blades and they wear kind of fast. Share this post Link to post Share on other sites
hairyconiption 0 Posted February 27, 2008 Wow that looks great. Could have used it a few times last month. Share this post Link to post Share on other sites
Guest Terry Posted February 27, 2008 We use these on the RC planes etc. They work great. It's extremely important to get the monokote, ultracote, econocote or vinyl dead straight on the roller to get a perfect straight strip. These use typical razor blades and they wear kind of fast. So can I use it for vinyl? or just the other stuff? is it electric? do you turn the handle to cut, or do you pull the vinyl through it? I see it uses regular X-acto blades. I have not checked the price in stores around here, but here is a cheap priced link. http://www.hobbylinc.com/cgi-bin/s7.cgi?cat_s=&age=&str=smart+stripe&sort_i=&show_i=&flag=&also_s= Share this post Link to post Share on other sites
dbtoutfit 5 Posted February 28, 2008 So can I use it for vinyl? or just the other stuff? is it electric? do you turn the handle to cut, or do you pull the vinyl through it? I see it uses regular X-acto blades. I have not checked the price in stores around here, but here is a cheap priced link. http://www.hobbylinc.com/cgi-bin/s7.cgi?cat_s=&age=&str=smart+stripe&sort_i=&show_i=&flag=&also_s= Yes, they will cut vinyl. These things are very manual. Additional pressure is needed on the blade to cut vinyl and ultracote. Try adjusting it so that the tip of the blade is cutting and not so much on the flat run of the blade. Xacto blades are a must. Cheap blades will simply make you pull your hair out. You should have a local hobby shop. (You know the places where you can buy rc planes, trucks, cars etc) They should have one in stock. This way you can simply walk in and look it over "hands-on" get an idea whether you'll like it or not, plus the benefit of saving s/h. All my Local hobby shops have this for about $21.00 so you should come out cheaper and with out the wait. Funny thing is. I got my Laserpoint to get away from this thing and your going towards it. lol You may find it more useful for quick tasks... maybe. Just FYI.. you can also cut monokote, ultracote (does the best) or econocote with a vinyl plotter. NOTE: It is important to get a fresh roll as the "cote's" lose there tacky-ness from their backing sort of quickly. If you have a roll of one of these "cote's" do not even attempt to cut it in the machine in the area where the cote has come lose from it's backing. It will be a disaster. Eric Share this post Link to post Share on other sites
